ATI Stream Software Development Kit v2.0 Beta 3 available
Started by Stefan, September 27, 2009, 06:54:46 AM
QuoteWhat's New in v2.0-beta3
    * ATI Stream SDK v2.0 OpenCLâ„¢ for x86 CPUs is now certified conformant by Khronos on September 3, 2009.
    * 64-bit atomic built-ins are now recognized.
    * Fixed some compiler assertion issues.
    * Fixed some incorrect compiler warnings.
    * Fixed some incorrect compiler assertion failures.
    * Fixed some code generation issues.
Supported Processors:
    * X86 CPU w/ SSE 3.x or later
Note:
You cannot mix ATI samples with NVIDIA runtime or vice versa because of different procedure entry points.
Therefore ATI's opencl.dll is not recognised by Everest Ultimate beta 1586
