RGB LED Matrix Demos Updated for Raspberry Pi 4
Version 0.16.0.0 - 2020.01.16+ added support of GPU monitoring for AMD Navi GPUs.+ added support of AMD Radeon RX 5500 XT.! updated: ZoomGPU 1.25.0 (GPU monitoring library) with NVAPI R440.
Hey. The program does not start, the message "gpushark.exe is not a Win32 application" appears. I first downloaded her. Checksums checked. OS Windows XP SP3 x32.
gpushark.exe /detailed_view /no_check_for_update /no_version_check
ChangelogVersion 0.12.4.0 - 2019.01.16 - removed support of Windows XP.
Version 0.16.1.0 - 2020.01.23+ added support of AMD Radeon RX 5600 XT.+ added support of GeForce RTX 2060 with TU104 GPU and GeForce GTX 1650 SUPER.! updated: ZoomGPU 1.25.1 (GPU monitoring library)
