Author Topic: Notepad++ 7.8.3 released  (Read 671 times)
« on: January 17, 2020, 10:04:40 AM »
2 key features in this release:
1/ Folder as Workspace is enhanced largely in this version, by adding 3 new capacities “Select/Show current editing editing file”, “Fold All” and “Expand All”.
2/ JSON syntax highlighting is improved as well - if you update from the old version, you should remove your langs.xml for the new syntax highlighting taking effect.
There are also a lot of important fixes and enhancements in this release, here are 2 most important fixed and enhanced issues:
1/ The fix of restoring line position issue while document is wrapped.
2/ Making filling find field of Find dialog with selected word(s) optional.
Notepad++ v7.8.3 enhancements and bug-fixes:
1.  Add the "Expand All", "Fold All" and "Select/Show current editing file" capacity into Folder as Workspace.
2.  Fix restoring line position issue while document is wrapped.
3.  Improve Json syntax highlighting.
4.  Make filling find field of Find dialog with selected word(s) optional.
5.  Make doSaveOrNot dialog simpler when there's a single file to save.
6.  Fix auto-insert {[""]} imbrication not working issue.
7.  Make cmd cli (for "Open Containing Folder in cmd") customizable.
8.  Prevent from setting Updater's Proxy as Notepad++ is not in Admin mode.
9.  Disable file association settings when Notepad++'s no admin right.
10. Fix incremental search bar "highlight all" option not conserved bug.
11. Enhance SQL syntax highlighting (add 2 more keyword lists).
12. Fix too small buffer issue during add text macro playback.
13. Fix "Close All Unchanged" not working issue for sub-view.
14. Eliminate garbage displaying in Find-result fold margin.
Included plugins:
1.  NppExport v0.2.9
2.  Converter 4.2.1
3.  Mime Tool 2.5
Updater (Installer only):
* WinGup (for Notepad++) v5.1.1
Links
- Download Notepad++ @ Geeks3D
- NPP 7.8.3 announcement
« Last Edit: January 17, 2020, 10:14:44 AM by JeGX »
