Author Topic: AMD Radeon Adrenalin 2020 Edition 20.1.1 Graphics Driver Released  (Read 1405 times)
Downloads
- Adrenalin for win10 64-bit @ Geeks3D
- Adrenalin for win7 64-bit @ Geeks3D
- Adrenalin 20.1.1 for win10 + win7 @ AMD
Release notes
Support For
- Monster Hunter World: Iceborne
Fixed Issues
- The audible beeps at game startup from Radeon Chill, Radeon Boost, and Radeon Anti-Lag have been removed. These features now offer audible indicators only when activated or deactivated via hotkey.
- The Radeon ReLive on screen timer indicator during recordings has been disabled by default but can be enabled in Radeon Software settings.
- Controls for vertical sync may be hidden or disappear when Radeon Enhanced Sync is enabled.
- Radeon ReLive may experience freezing or pausing issues during recordings when a high resolution camera is connected and in use.
- CPU usage may sometimes remain high once Radeon Game Advisor has been invoked during a game.
- Some users may experience an error message “Another instance is running” during download of a software update through the Radeon Software home screen.
- The DuplicateDesktop process may sometimes cause high CPU usage while a game is running.
- Radeon Software may close or may experience a crash upon resuming from sleep.
- The toast message detailing the hotkey to open Radeon Software’s Overlay may still show up in some games after Radeon Software Overlay has been disabled.
- Lost Ark may experience stuttering intermittently during gameplay.
- Using a custom stream key with Radeon ReLive may fail to stream your content.
- The Stream button may remain active when in the process of choosing a region to stream even when a region has not been selected or chosen.
- Some Radeon R9 200, Radeon R9 300 and Radeon R9 Fury series graphics products may experience instability with a limited number of DirectX9 or DirectX11 games when using a high refresh rate 120hz+ display. A workaround if you are experiencing this issue is to lower your displays refresh rate.
- Some mjpeg clips may experience a green tint on Radeon RX 5700 series graphics products when using Windows® Media Player or the Movies & TV application.
- MechWarrior 5: Mercenaries™ may experience a game crash and DXGI dialogue error when running the game using HDMI and Radeon FreeSync display configurations.
- Live streaming using the DouYu™ application with hardware acceleration enabled may cause video corruption on Radeon RX 5700 series graphics products.
- Trials Rising may experience excessive fog/smoke in some areas of the game.
- Missing text or corruption may be experienced in the right eye when playing the VR game Boneworks™.
- Fixed result overflows that can be experienced with Radeon RX 5700 series when using SETI@Home.
- The Shop AMD Products button may open the AMD.com homepage instead of the proper shopping web link.
- The scrolling arrow options may intermittently fail to work during Radeon Software installation.
- Up and Down arrow keys don’t work when using the search bar in Radeon Software.
- Enabling HDR enabled displays in Windows® may cause colors to become washed out.
- Radeon Software sidebar appears behind the Windows® taskbar when the taskbar is set to the same side of your display.
- Playing Tom Clancy's: The Division 2 with HDR enabled and performing a task switch may cause display color corruption that persists even once the game is exited.
- Mixed Reality Portal may experience color corruption or distortion near the edge of viewing areas on some headsets.
- Resident Evil 2 may experience screen flashing when launching the game using DirectX®12 API.
AMD Radeon Adrenalin 20.1.1
AMD Radeon Adrenalin 20.1.1 + Radeon RX Vega 56 + GPU Caps Viewer
The Adrenalin 20.1.1 exposes the same OpenGL and Vulkan support than previous 19.12.3:
OpenGL
- GL_RENDERER: Radeon RX Vega
- GL_VENDOR: ATI Technologies Inc.
- GL_VERSION: 4.6.13586 Compatibility Profile Context 20.1.1 26.20.15011.5007
- OpenGL extensions: 327
Vulkan
  - name: Radeon RX Vega
  - device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
  - device ID: 1002-687F
  - API version: 1.1.129
  - VK_KHR_driver_properties information:
    - driverName: AMD proprietary driver
    - driverID_str: VK_DRIVER_ID_AMD_PROPRIETARY_KHR
    - driverID: 1
    - conformanceVersion: 1.1.3.2
    - driverInfo: 20.1.1
  - # of extensions => 97
