Author Topic: Radeon GPU Profiler 1.7 released  (Read 1244 times)
« on: January 08, 2020, 01:57:49 PM »
The Radeon GPU Profiler (RGP) is a ground-breaking low-level optimization tool from AMD. It provides detailed timing information on Radeon Graphics using custom, built-in, hardware thread-tracing, allowing the developer deep inspection of GPU workloads.
We are happy to announce the release of Radeon™ GPU Profiler (RGP) v1.7. This release adds support for the latest Radeon™ graphics cards: the RX 5500 series and the RX 5300 series. In addition, this release adds new UI features to help you better understand your GPU workloads.
Changes
Radeon GPU Profiler
    Support for Radeon RX 5500 and Radeon RX 5300 hardware
    New Pipelines Overview pane to summarize pipeline usage for the profile
    Pipelines and Pipeline state views will indicate if a shader was compiled using wave32 vs. wave64
    on RDNA hardware
    In the Barriers pane, additional cache levels (L0/L1/L2) are shown for invalidates on RDNA hardware
    The Most expensive events and Render/depth targets panes now have sortable table columns
    The Frame Summary and Profile Summary panes now show the amount of profiling overhead (the amount
    of video memory and bandwidth consumed by profile data collection)
    Add Overlays in the Wavefront Occupancy Event Timeline view to view User events, Hardware contexts,
    Command buffers and Render targets
    Improved Instruction Timing to increase accuracy of timing data
    Improved zoom control UI in the various panes that support zooming
    Improved UI when running at different DPI settings
    Bug/stability fixes
Radeon Developer Panel
    Support capturing OpenCL profiles on Radeon RX 5700 hardware
Links
- Downloads
- Homepage
- RPG 1.7 announcement
