MSI Gaming Radeon Rx 5700 Xt
Started by Edward11, January 05, 2020, 06:25:45 AM
Edward11
I am in the market for replacing my 1050 Ti that came with my pre-built pc. I saw some videos saying that the AMD Radeon 5700 xt is almost comparable to the 2060 super. I am still new to computer building and discovered a problem. My 1050 Ti is about 5.7 inches long and my new graphics card I want is 11.3 inches long, and my motherboard is 2.4 x 10 x 11.3 inches. I also don't know compatibility wise if it will fit since these 2 different companies are making these GPU's... I need some advice.
NOTE: spammer!
It's a common problem that you can't easily replace hardware in a pre-built PC.Besides the physical space make sure that the new GPU doesn't need more power as pre-built PCs come with weak PSUs.Also they have restricted BIOS which can cause trouble.
I suggest to visit the PC manufacturer's website and look for an upgrade kit recommended by them.
