Problem with Furmark in Lenovo Yoga
Started by luskoefusko, December 14, 2019, 09:12:10 PM
luskoefusko
Hello, I would like to ask you a question.
I have a Lenovo Yoga with a GEFORCE 940MX graphics card and Furmark doesn't work for me. He says it requires an OpenGL 2.0 compliant graphics controller... Nvidia Geforce 6 and higer...
Any idea?
Thank you.
Sounds like the GeForce driver is not properly installed, i.e. "Microsoft basic display adapter" is active.
Can you post a screenshot from the main tab and the OpenGL tab of GPU Caps Viewer?
mark435
#2
I just had this problem and the issue was with BIOS, I flashed new one and Furmark works fine. https://www.hlplanet.com/nordvpn-add-vpn-configurations/
