Author Topic: NVIDIA GeForce driver 440.44 for Linux, FreeBSD and Solaris  (Read 1048 times)
« on: December 11, 2019, 04:29:31 PM »
  • Added support for the following GPU:
    • Quadro T2000 with Max-Q Design
  • Added support for the __GL_SYNC_DISPLAY_DEVICE environment variable for Vulkan applications.
  • Fixed a bug that caused applications running directly on a display (such as VR HMDs) to tear when a G-SYNC or G-SYNC Compatible monitor is plugged in the system.
  • Fixed a bug in an error handling path that could cause a kernel crash while loading nvidia.ko.
  • Fixed driver installation failure on Oracle Linux 7.7 systems, where the NVIDIA kernel module failed to build with error "unknown type name 'vm_fault_t'".
  http://de.download.nvidia.com/XFree86/Linux-x86_64/440.44/NVIDIA-Linux-x86_64-440.44.run
 http://us.download.nvidia.com/XFree86/FreeBSD-x86_64/440.44/NVIDIA-FreeBSD-x86_64-440.44.tar.gz
 http://fr.download.nvidia.com/solaris/440.44/NVIDIA-Solaris-x86-440.44.run
