EVEREST Ultimate Edition 5.02.1854 beta available
Started by Stefan, September 20, 2009, 04:05:55 PM
QuoteBeta Downloads
preliminary GPU information for ATI Radeon HD 5xxx (Cypress)
preliminary GPU information for nVIDIA GeForce 3xx
Display / GPGPU / improved OpenCL devices information for nVIDIA GPUs
OpenCL infos of my GPU, way too many "not supported" lines  :P
QuoteDevice Properties
Device Name   GeForce 8800 GTX
Device Type   GPU
Device Vendor   NVIDIA Corporation
Device Version   OpenCL 1.0
Device Profile   Full
Clock Rate   1350 MHz
Multiprocessors   16
Max 2D Image Size   8192 x 8192
Max 3D Image Size   2048 x 2048 x 2048
Max Samplers   16
Max Argument Size   4352 bytes
Max Constant Buffer Size   64 KB
Max Constant Arguments   9
Profiling Timer Resolution   1000 ns
OpenCL DLL   opencl.dll (7.16.11.9089 - nVIDIA ForceWare 190.89)
Memory Properties
Global Memory   768 MB
Local Memory   16 KB
Device Features
Command-Queue Out Of Order Execution   Enabled
Command-Queue Profiling   Enabled
Compiler   Supported
Error Correction   Not Supported
Images   Supported
Kernel Execution   Supported
Native Kernel Execution   Not Supported
Device Extensions
cl_khr_3d_image_writes   Not Supported
cl_khr_byte_addressable_store   Supported
cl_khr_fp16   Not Supported
cl_khr_fp64   Not Supported
cl_khr_global_int32_base_atomics   Not Supported
cl_khr_global_int32_extended_atomics   Not Supported
cl_khr_int64_base_atomics   Not Supported
cl_khr_int64_extended_atomics   Not Supported
cl_khr_local_int32_base_atomics   Not Supported
cl_khr_local_int32_extended_atomics   Not Supported
cl_khr_select_fprounding_mode   Not Supported
cl_nv_compiler_options   Supported
cl_nv_device_attribute_query   Supported
