FurMark in Dynamic Camera mode says volt:1 in limits... what does that mean?
Started by Yana Asewana, July 17, 2019, 11:22:44 PM
Yana Asewana
Hello ! Basically what it says on the tin can  ;D
Tried running furmark in dynamic camera mode.
Having "volt:1" show up in limits... not sure what that means - I did try to google.
Only happens in dynamic camera mode.
In the other mode the "volt" limit is not hit
Card is MSI Gaming 1070, all clocks and stuff are stock.
Could someone please explain what the "volt:1" limit even is?
Quote from: Yana Asewana on July 17, 2019, 11:22:44 PM
Pascal GPUs are are more sensitive to voltage (see here) and depending on the scene/graphics load, your GPU can reach the voltage limit before other limits (temperature, power, or overvoltage).
