Author Topic: AMD Radeon Software Adrenalin Edition 19.7.1  (Read 1749 times)
« on: July 07, 2019, 03:52:53 PM »
Radeon Software Adrenalin 2019 Edition 19.7.1 Highlights
 Support For
  • AMD Radeon™ RX 5700 Series Graphics
  • AMD Radeon Image Sharpening(1)
    • New feature available in Radeon Settings that can be enabled for DirectX®9, DirectX®11 and Vulkan® games on AMD Radeon RX 5700 Series Graphics. Provides contrast-adaptive sharpening combined with optional GPU upscaling that helps draw out detail and provide crisp-looking visuals.
  • AMD Radeon Anti-Lag(2)
    • New feature available in Radeon Settings that can be enabled for DirectX®9 and DirectX®11 games that improves input-to-display response time with up to 31% reduction in lag.RS-295
  • AMD Link(3)
    • Now supports auto-discovery mode and one-tap connection, allowing you to easily connect your Radeon PC and AMD Link App.
    • Now supports connections to Apple TV and Android TV with a new simplified TV interface.
  • AMD Radeon Chill(4)
    • Now supports display-aware tuning which sets frame-rate caps to match your monitors refresh rate providing up to 2.5x more power savings than before.RS-294 Display-aware tuning works with fixed-refresh monitors or with variable-refresh Radeon FreeSync™-capable displays.
  • AMD Radeon WattMan(5)
    • New power gauge readout available in Performance Metrics Overlay and Radeon WattMan.
    • Auto Tuning features now provide a summary readout of tuning changes.
  • Settings Snapshot(6)
    • New feature available in Radeon Settings that allows you to create, save and load your custom settings and configurations for Radeon Settings.
  • Automatic Low Latency Mode(7)
    • Allows supported graphics products to communicate with your connected TV and enter low-latency (gaming) mode automatically.
Fixed Issues
  • Graphics driver may not uninstall correctly when using the express uninstall option on some Ryzen APUs.
  • Performance Metrics Overlay may intermittently display incorrect colors when being displayed in game.
  • Radeon Overlay may fail to appear or invoke when playing DOOM™.
  • Radeon Overlay may fail to appear or invoke when a game is running fullscreen on Windows®7 system configurations.
  • Some users may be experiencing AMD DLL file signing issues with Easy Anti-Cheat™. A clean install of Radeon Software Adrenalin 2019 Edition 19.7.1 may be required to fix this issue.
