Linux GPU stress test with chosen board option
Started by oreny1306, May 22, 2019, 09:36:57 AM
oreny1306
Hi Friends,
I have new linux server with two GPU boards GTX 1080 TI.
I want to run stress test that i can chose with board to stress or both of them.
Please tour help
Tx,
Oren
oreny1306
Cuda-z have this option but heavy load stress not realy heavy.....
The only end-user benchmark I have for Linux is GpuTest. But GpuTest has no option to select the GPU. It's an OpenGL benchmark. You can perhaps force GpuTest to use a particular GPU by launching it on the right monitor (assuming you have a monitor connected to each GPU). But I'm not sure if this works. The successor of GpuTest will have Vulkan support which will make easier the selection of a particular GPU.
oreny1306
tx for your answer , cuda-z you can chose with GPU to stress... but Gpu loaded only 80 %
maybe someone else can help with?
