Author Topic: Intel Graphics - Windows 10 DCH Drivers Version: 26.20.100.6861  (Read 1186 times)
Intel Graphics - Windows 10 DCH Drivers Version: 26.20.100.6861 (Latest) Date: 5/15/2019
Highlights
   Performance Improvements:
  • Improved performance and image quality when Conservative Morphological Anti-Aliasing (CMAA) is enabled for DX12 games and 3D applications.
  • Reduced compilation time on OpenCL shaders
  • Playability improvements and performance optimizations for Total War: Three Kingdoms*, Totally Accurate Battle Simulator*, and Risk of Rain 2*
  Developer Highlights:
  • Support for OpenGL 4.6 API
  • Various additions to D3D12 MetaCommand support in DirectML.
  • The IntelĀ® Graphics Control Panel SDK now allows for control of Local Adaptive Contrast Enhancement (LACE) sensitivity (low/med/high) on platforms where available
  • New Vulkan extensions
    • VK_EXT_depth_clip_enable : allows the explicitly  control depth clipping operation
    • VK_EXT_host_query_reset : adds a new function to reset queries from the host
    • VK_EXT_scalar_block_layout : enables C-like structure layout for SPIR-V blocks
    • VK_KHR_shader_float16_int8 : allows use of 16-bit floating-point types and 8-bit integer types in shaders for arithmetic operations
