Author Topic: AMD Navi thread  (Read 1430 times)
AMD Navi thread
« on: April 29, 2019, 02:11:18 PM »
Navi based graphics cards should be unveiled during the Computex 2019, next June.
The PCB has two 8-pin power connectors (the board will be able to draw up to 375W). The GPU is surrounded by 8 memory modules (GDDR6).
This is likely the PCB of Navi 10 (gfx1010).
AMD Navi PCB
AMD Navi PCB
- https://www.techpowerup.com/254992/amd-navi-graphics-card-pcb-pictured-uses-gddr6
AMD Navi PCB
source: https://twitter.com/KOMACHI_ENSAKA/status/1118172398782599168
« Last Edit: April 29, 2019, 03:43:34 PM by JeGX »
AMD Navi RX 3080 specs leaked
« Reply #1 on: May 24, 2019, 11:58:27 AM »
AMD Radeon RX 3080 specs:
- GPU: Navi XT
- Stream processors: 2560
- 8 shader engines (5 compute units per shader engine, 64 stream processors per compute unit)
- Memory: 8 to 16 GB, memory interface width: 256-bit
- launch price: USD $499
AMD Radeon RX 3070 specs:
- GPU: Navi PRO
- launch price: USD $399
via: https://wccftech.com/amd-radeon-navi-rx-3080-specs-leaked-8-shader-engines-2560-sps-8gb-vram-256-bit-bus/
