Author Topic: NVIDIA Nsight Systems 2019.3 Adds Vulkan Support  (Read 1092 times)
« on: April 24, 2019, 10:28:45 AM »
NVIDIA Nsight Systems is a system-wide performance analysis tool designed to visualize an application’s algorithm, help you select the largest opportunities to optimize, and tune to scale efficiently across any quantity of CPUs and GPUs in your computer; from laptops to DGX servers.
Nsight Systems release 2019.3 adds Vulkan support for Microsoft Windows and Linux operating systems. The tool can capture information about the profiled process usage of Vulkan, including Vulkan API function execution time, corresponding GPU workloads, debug util labels, and frame durations. Both Windows x64 and Linux operating systems support Vulkan profiling.
2019.3 Release Highlights
- Vulkan & VKRay API & GPU trace
- Frame health indicator for stutter analysis
- Extended set of Direct3D12 functions traces
- Exporters for SQLite & JSON (beta)
- Windows Symbols Server support
- Windows SSH remote profiling
- Windows GPU memory utilizationT
- NVIDIA Nsight Systems Adds Vulkan Support @ NVIDIA blog
- NVIDIA Nsight Systems hompage
- Nsight Systems Downloads
NVIDIA Nsight Systems 2019.3 + Vulkan profiling
