Author Topic: NVIDIA GeForce driver 430.09 for Linux, FreeBSD and Solaris  (Read 5597 times)
« on: April 23, 2019, 06:21:24 PM »
  • Added support for the following GPU:
    • GeForce GTX 1650
       GeForce GTX 1650 with Max-Q Design
       GeForce GTX 1660 Ti with Max-Q Design
  • Fixed a bug that could cause the display to be driven at a low
     resolution when configuring PRIME display offloading with
     nvidia-xconfig --prime`.
  • Added HEVC YUV 4:4:4 decode support to the NVIDIA VDPAU driver.
  • Added the new per-decoder profile capability bit
     VDP_DECODER_PROFILE_SUPPORTED_CHROMA_TYPES to the NVIDIA VDPAU driver.
  • Added new VdpYCbCrFormats VDP_YCBCR_FORMAT_Y_UV_444 and
     VDP_YCBCR_FORMAT_Y_U_V_444 for accessing YUV 4:4:4 surfaces via
     VdpVideoSurfaceGetBitsYCbCr() and VdpVideoSurfacePutBitsYCbCr()
     in the NVIDIA VDPAU driver.
  • Added support for creation of YUV 4:4:4 video surfaces in the NVIDIA VDPAU driver.
  • Raised the minimum supported X.Org xserver version to 1.7 (video driver ABI version 6).
  • Updated the NVIDIA VDPAU driver to support allocating VDPAU video surfaces with explicit field or frame picture structure.
  • Added support for the GL_NV_vdpau_interop2 OpenGL extension, which allows VDPAU/OpenGL surface sharing with explicit field or frame picture structure. Picture structure selection by applications can avoid the need for implicit surface structure conversion by the OpenGL implementation.
  • Updated nvidia-installer for better compatibility with ncurses when libncurses.so.6 exposes the ncurses reentrant ABI, such as on openSUSE Leap 15 and SUSE Linux Enterprise 15.
  http://de.download.nvidia.com/XFree86/Linux-x86_64/430.09/NVIDIA-Linux-x86_64-430.09.run
 http://us.download.nvidia.com/XFree86/FreeBSD-x86_64/430.09/NVIDIA-FreeBSD-x86_64-430.09.tar.gz
 http://fr.download.nvidia.com/solaris/430.09/NVIDIA-Solaris-x86-430.09.run
