Cannot generate FurMark-Score.txt by command
Started by FuWei77, April 17, 2019, 09:30:33 AM
FuWei77
I encounter a symptom that I run Furmark v1.20.5.0 with below command I often use to generate the result about furmark result.
But FurMark-Score.txt still doesn't exist with my result after running complete and furmark windows closed.
FurMark.exe /nogui /width=1024 /height=728 /noscore /log_score /log_gpu_data_polling_factor=10 /run_mode=1 /max_time=15000
I try to let my laptop update Graphic driver to the latest but still doesn't work.
Intel UHD Graphic 630, Intel Graphic driver: v25.20.100.6617
Nvidia Geforce GTX 1080, Nvidia Graphic driver: v25.21.14.1972
OS: Win10 1809
Would geeks3d please help to see what's going on?
I did a test with your command line and the FurMark-Scores.txt file is correctly updated. Could your try to run your command line with admin rights?
FuWei77
Hi JeGX,
I always use command line with admin but it cannot update FurMark-Scores.txt .
I clear Application event log then do it again and found something wrong with APPCRASH event.
I don't know how to attach log for your reference but log indicates APPCRASH relates to FurMark.exe and nvoglv32.dll.
[Windows Error Reporting]:
Fault bucket , type 0
Event Name: APPCRASH
Response: Not available
Cab Id: 0
Problem signature:
P1: FurMark.exe
P2: 1.20.5.0
P3: 5cadaaba
P4: nvoglv32.dll
P5: 25.21.14.1972
P6: 5c8fdf4b
P7: c0000005
P8: 0093b251
P9:
P10:
[Application Error]:
Faulting application name: FurMark.exe, version: 1.20.5.0, time stamp: 0x5cadaaba
Faulting module name: nvoglv32.dll, version: 25.21.14.1972, time stamp: 0x5c8fdf4b
Exception code: 0xc0000005
Fault offset: 0x0093b251
Faulting process id: 0x12bc
Faulting application start time: 0x01d4f6d73a40f3ea
Faulting application path: C:\Program Files (x86)\Geeks3D\Benchmarks\FurMark\FurMark.exe
Faulting module path: C:\Windows\System32\DriverStore\FileRepository\nvdmegpu.inf_amd64_02be0d916b60becc\nvoglv32.dll
Report Id: e71786a5-80de-4fe7-b9c8-204c07199235
Faulting package full name:
Faulting package-relative application ID:
FuWei77
Furmark score.txt can be generated after nVidia driver update to v430.64.
