Author Topic: NVIDIA Vulkan developer driver 419.62  (Read 1328 times)
« on: March 17, 2019, 10:40:29 PM »
 Windows driver version 419.62 and Linux driver version 418.49.04 provide new features for Vulkan developers to test their upcoming Vulkan applications.
 Windows 419.62
   Linux 418.49.04
   Release Updates
  March 16th, 2019 - Windows 419.62, Linux 418.49.04
New:
NVIDIA Vulkan developer driver 419.62 - GL/VK RTX 2080
« Reply #1 on: March 19, 2019, 08:45:04 AM »
OpenGL
- GL_RENDERER => GeForce RTX 2080/PCIe/SSE2
- GL_VENDOR => NVIDIA Corporation
- GL_VERSION => 4.6.0 NVIDIA 419.62
- 419 extensions (complete list available HERE)
Vulkan
- name: GeForce RTX 2080
- device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
- device ID: 10DE-1E87
- API version: 1.1.103
- NVIDIA driver version: 419.62.0.0
GPU Caps Viewer + GeForce RTX 2080
NVIDIA Vulkan developer driver 419.62 - Vulkan info / RTX 2080
« Reply #2 on: March 19, 2019, 08:50:01 AM »
Report from GPU Shark 2 (not yet released).
# of instance extensions => 12
- 001/ VK_KHR_surface
- 002/ VK_KHR_win32_surface
- 003/ VK_KHR_external_memory_capabilities
- 004/ VK_KHR_external_semaphore_capabilities
- 005/ VK_KHR_external_fence_capabilities
- 006/ VK_KHR_get_physical_device_properties2
- 007/ VK_KHR_get_surface_capabilities2
- 008/ VK_KHR_device_group_creation
- 009/ VK_EXT_swapchain_colorspace
- 010/ VK_EXT_debug_report
- 011/ VK_EXT_debug_utils
- 012/ VK_NV_external_memory_capabilities
# of instance layers => 3
- 001/ VK_LAYER_NV_optimus
- 002/ VK_LAYER_VALVE_steam_overlay
- 003/ VK_LAYER_LUNARG_standard_validation
# of Vulkan devices => 2
- Device 1
  - # of extensions => 90
  - 001/ VK_KHR_8bit_storage
  - 002/ VK_KHR_16bit_storage
  - 003/ VK_KHR_bind_memory2
  - 004/ VK_KHR_create_renderpass2
  - 005/ VK_KHR_dedicated_allocation
  - 006/ VK_KHR_depth_stencil_resolve
  - 007/ VK_KHR_descriptor_update_template
  - 009/ VK_KHR_draw_indirect_count
  - 010/ VK_KHR_driver_properties
  - 011/ VK_KHR_external_fence
  - 012/ VK_KHR_external_fence_win32
  - 013/ VK_KHR_external_memory
  - 014/ VK_KHR_external_memory_win32
  - 015/ VK_KHR_external_semaphore
  - 016/ VK_KHR_external_semaphore_win32
  - 017/ VK_KHR_get_memory_requirements2
  - 018/ VK_KHR_image_format_list
  - 019/ VK_KHR_maintenance1
  - 020/ VK_KHR_maintenance2
  - 021/ VK_KHR_maintenance3
  - 022/ VK_KHR_multiview
  - 023/ VK_KHR_push_descriptor
  - 024/ VK_KHR_relaxed_block_layout
  - 025/ VK_KHR_sampler_mirror_clamp_to_edge
  - 026/ VK_KHR_sampler_ycbcr_conversion
  - 027/ VK_KHR_shader_atomic_int64
  - 028/ VK_KHR_shader_draw_parameters
  - 029/ VK_KHR_shader_float16_int8
  - 030/ VK_KHR_shader_float_controls
  - 031/ VK_KHR_storage_buffer_storage_class
  - 032/ VK_KHR_swapchain
  - 033/ VK_KHR_swapchain_mutable_format
  - 034/ VK_KHR_variable_pointers
  - 035/ VK_KHR_vulkan_memory_model
  - 036/ VK_KHR_win32_keyed_mutex
  - 037/ VK_EXT_blend_operation_advanced
  - 038/ VK_EXT_buffer_device_address
  - 039/ VK_EXT_conditional_rendering
  - 040/ VK_EXT_conservative_rasterization
  - 041/ VK_EXT_depth_clip_enable
  - 042/ VK_EXT_depth_range_unrestricted
  - 043/ VK_EXT_descriptor_indexing
  - 044/ VK_EXT_discard_rectangles
  - 045/ VK_EXT_external_memory_host
  - 046/ VK_EXT_hdr_metadata
  - 047/ VK_EXT_host_query_reset
  - 048/ VK_EXT_inline_uniform_block
  - 049/ VK_EXT_memory_budget
  - 050/ VK_EXT_memory_priority
  - 051/ VK_EXT_pci_bus_info
  - 052/ VK_EXT_post_depth_coverage
  - 053/ VK_EXT_sample_locations
  - 054/ VK_EXT_sampler_filter_minmax
  - 055/ VK_EXT_scalar_block_layout
  - 056/ VK_EXT_shader_subgroup_ballot
  - 057/ VK_EXT_shader_subgroup_vote
  - 058/ VK_EXT_shader_viewport_index_layer
  - 059/ VK_EXT_transform_feedback
  - 060/ VK_EXT_vertex_attribute_divisor
  - 061/ VK_EXT_ycbcr_image_arrays
  - 062/ VK_NV_clip_space_w_scaling
  - 063/ VK_NV_compute_shader_derivatives
  - 064/ VK_NV_cooperative_matrix
  - 065/ VK_NV_corner_sampled_image
  - 066/ VK_NV_dedicated_allocation
  - 067/ VK_NV_dedicated_allocation_image_aliasing
  - 068/ VK_NV_device_diagnostic_checkpoints
  - 069/ VK_NV_external_memory
  - 070/ VK_NV_external_memory_win32
  - 071/ VK_NV_fill_rectangle
  - 072/ VK_NV_fragment_coverage_to_color
  - 073/ VK_NV_fragment_shader_barycentric
  - 074/ VK_NV_framebuffer_mixed_samples
  - 075/ VK_NV_geometry_shader_passthrough
  - 076/ VK_NV_mesh_shader
  - 077/ VK_NV_sample_mask_override_coverage
  - 078/ VK_NV_representative_fragment_test
  - 079/ VK_NV_scissor_exclusive
  - 080/ VK_NV_shader_image_footprint
  - 081/ VK_NV_shader_subgroup_partitioned
  - 082/ VK_NV_shading_rate_image
  - 083/ VK_NV_viewport_array2
  - 084/ VK_NV_viewport_swizzle
  - 085/ VK_NV_win32_keyed_mutex
  - 086/ VK_NVX_binary_import
  - 087/ VK_NVX_device_generated_commands
  - 088/ VK_NVX_image_view_handle
  - 089/ VK_NVX_multiview_per_view_attributes
  - 090/ VK_NV_ray_tracing
  - # of layers => 1
  - # of memory heaps => 2
  - heap 1 => 8010 MB
  - heap 2 => 8121 MB
  - # of features => 55
  - 001/ robustBufferAccess => 1
  - 002/ fullDrawIndexUint32 => 1
  - 003/ imageCubeArray => 1
  - 004/ independentBlend => 1
  - 005/ geometryShader => 1
  - 006/ tessellationShader => 1
  - 007/ sampleRateShading => 1
  - 008/ dualSrcBlend => 1
  - 009/ logicOp => 1
  - 010/ multiDrawIndirect => 1
  - 011/ drawIndirectFirstInstance => 1
  - 012/ depthClamp => 1
  - 013/ depthBiasClamp => 1
  - 014/ fillModeNonSolid => 1
  - 015/ depthBounds => 1
  - 016/ wideLines => 1
  - 017/ largePoints => 1
  - 018/ alphaToOne => 1
  - 019/ multiViewport => 1
  - 020/ samplerAnisotropy => 1
  - 021/ textureCompressionETC2 => 0
  - 022/ textureCompressionASTC_LDR => 0
  - 023/ textureCompressionBC => 1
  - 024/ occlusionQueryPrecise => 1
  - 025/ pipelineStatisticsQuery => 1
  - 026/ vertexPipelineStoresAndAtomics => 1
  - 027/ fragmentStoresAndAtomics => 1
  - 028/ shaderTessellationAndGeometryPointSize => 1
  - 029/ shaderImageGatherExtended => 1
  - 030/ shaderStorageImageExtendedFormats => 1
  - 031/ shaderStorageImageMultisample => 1
  - 032/ shaderStorageImageReadWithoutFormat => 1
  - 033/ shaderStorageImageWriteWithoutFormat => 1
  - 034/ shaderUniformBufferArrayDynamicIndexing => 1
  - 035/ shaderSampledImageArrayDynamicIndexing => 1
  - 036/ shaderStorageBufferArrayDynamicIndexing => 1
  - 037/ shaderStorageImageArrayDynamicIndexing => 1
  - 038/ shaderClipDistance => 1
  - 039/ shaderCullDistance => 1
  - 040/ shaderFloat64 => 1
  - 041/ shaderInt64 => 1
  - 042/ shaderInt16 => 1
  - 043/ shaderResourceResidency => 1
  - 044/ shaderResourceMinLod => 1
  - 045/ sparseBinding => 1
  - 046/ sparseResidencyBuffer => 1
  - 047/ sparseResidencyImage2D => 1
  - 048/ sparseResidencyImage3D => 1
  - 049/ sparseResidency2Samples => 1
  - 050/ sparseResidency4Samples => 1
  - 051/ sparseResidency8Samples => 1
  - 052/ sparseResidency16Samples => 1
  - 053/ sparseResidencyAliased => 1
  - 054/ variableMultisampleRate => 1
  - 055/ inheritedQueries => 1
  - # of hardware limits => 106
    - 001/ maxImageDimension1D => 32768
    - 002/ maxImageDimension2D => 32768
    - 003/ maxImageDimension3D => 16384
    - 004/ maxImageDimensionCube => 32768
    - 005/ maxImageArrayLayers => 2048
    - 006/ maxTexelBufferElements => 134217728
    - 007/ maxUniformBufferRange => 65536
    - 008/ maxStorageBufferRange => 4294967295
    - 009/ maxPushConstantsSize => 256
    - 010/ maxMemoryAllocationCount => 4096
    - 011/ maxSamplerAllocationCount => 4000
    - 012/ bufferImageGranularity => 1024
    - 013/ sparseAddressSpaceSize => -1
    - 014/ maxBoundDescriptorSets => 32
    - 015/ maxPerStageDescriptorSamplers => 1048576
    - 016/ maxSamplerAllocationCount => 1048576
    - 017/ maxPerStageDescriptorStorageBuffers => 1048576
    - 018/ maxPerStageDescriptorSampledImages => 1048576
    - 019/ maxPerStageDescriptorStorageImages => 1048576
    - 020/ maxPerStageDescriptorInputAttachments => 1048576
    - 021/ maxPerStageResources => 4294967295
    - 022/ maxDescriptorSetSamplers => 1048576
    - 023/ maxDescriptorSetUniformBuffers => 1048576
    - 024/ maxDescriptorSetUniformBuffersDynamic => 15
    - 025/ maxDescriptorSetStorageBuffers => 1048576
    - 026/ maxDescriptorSetStorageBuffersDynamic => 16
    - 027/ maxDescriptorSetSampledImages => 1048576
    - 028/ maxDescriptorSetStorageImages => 1048576
    - 029/ maxDescriptorSetInputAttachments => 1048576
    - 030/ maxVertexInputAttributes => 32
    - 031/ maxVertexInputBindings => 32
    - 032/ maxVertexInputAttributeOffset => 2047
    - 033/ maxVertexInputBindingStride => 2048
    - 034/ maxVertexOutputComponents => 128
    - 035/ maxTessellationGenerationLevel => 64
    - 036/ maxTessellationPatchSize => 32
    - 037/ maxTessellationControlPerVertexInputComponents => 128
    - 038/ maxTessellationControlPerVertexOutputComponents => 128
    - 039/ maxTessellationControlPerPatchOutputComponents => 120
    - 040/ maxTessellationControlTotalOutputComponents => 4216
    - 041/ maxTessellationEvaluationInputComponents => 128
    - 042/ maxTessellationEvaluationOutputComponents => 128
    - 043/ maxGeometryShaderInvocations => 32
    - 044/ maxGeometryInputComponents => 128
    - 045/ maxGeometryOutputComponents => 128
    - 046/ maxGeometryOutputVertices => 1024
    - 047/ maxGeometryTotalOutputComponents => 1024
    - 048/ maxFragmentInputComponents => 128
    - 049/ maxFragmentOutputAttachments => 8
    - 050/ maxFragmentDualSrcAttachments => 1
    - 051/ maxFragmentCombinedOutputResources => 16
    - 052/ maxComputeSharedMemorySize => 49152
    - 053/ maxComputeSharedMemorySize => 2147483647 x 65535 x 65535
    - 054/ maxComputeWorkGroupInvocations => 1024
    - 055/ maxComputeWorkGroupSize => 1024 x 1024 x 64
    - 056/ subPixelPrecisionBits => 8
    - 057/ subTexelPrecisionBits => 8
    - 058/ mipmapPrecisionBits => 8
    - 059/ maxDrawIndexedIndexValue => 4294967295
    - 060/ maxDrawIndirectCount => 4294967295
    - 061/ maxSamplerLodBias => 15.000000
    - 062/ maxSamplerAnisotropy => 16.000000
    - 063/ maxViewports => 16
    - 064/ maxViewportDimensions => 32768 x 32768
    - 065/ viewportBoundsRange => -65536.000000 x 65536.000000
    - 066/ viewportSubPixelBits => 8
    - 067/ minMemoryMapAlignment => 64
    - 068/ minTexelBufferOffsetAlignment => 16
    - 069/ minUniformBufferOffsetAlignment => 64
    - 070/ minStorageBufferOffsetAlignment => 32
    - 071/ minTexelOffset => -8
    - 072/ maxTexelOffset => 7
    - 073/ minTexelGatherOffset => -32
    - 074/ maxTexelGatherOffset => 31
    - 075/ minInterpolationOffset => -0.500000
    - 076/ maxInterpolationOffset => 0.437500
    - 077/ subPixelInterpolationOffsetBits => 4
    - 078/ maxFramebufferWidth => 32768
    - 079/ maxFramebufferHeight => 32768
    - 080/ maxFramebufferLayers => 2048
    - 081/ framebufferColorSampleCounts => 15
    - 082/ framebufferDepthSampleCounts => 15
    - 083/ framebufferStencilSampleCounts => 31
    - 084/ framebufferNoAttachmentsSampleCounts => 31
    - 085/ maxColorAttachments => 8
    - 086/ sampledImageColorSampleCounts => 15
    - 087/ sampledImageIntegerSampleCounts => 15
    - 088/ sampledImageDepthSampleCounts => 15
    - 089/ sampledImageStencilSampleCounts => 31
    - 090/ storageImageSampleCounts => 15
    - 091/ maxSampleMaskWords => 1
    - 092/ timestampComputeAndGraphics => 1
    - 093/ timestampPeriod => 1.000000
    - 094/ maxClipDistances => 8
    - 095/ maxCullDistances => 8
    - 096/ maxCombinedClipAndCullDistances => 8
    - 097/ discreteQueuePriorities => 2
    - 098/ pointSizeRange => 1.000000 x 2047.937500
    - 099/ lineWidthRange => 1.000000 x 64.000000
    - 100/ pointSizeGranularity => 0.062500
    - 101/ lineWidthGranularity => 1.000000
    - 102/ strictLines => 1
    - 103/ standardSampleLocations => 1
    - 104/ optimalBufferCopyOffsetAlignment => 1
    - 105/ optimalBufferCopyRowPitchAlignment => 1
    - 106/ nonCoherentAtomSize => 64
- Device 2
  - name: Intel(R) UHD Graphics 630
  - device type: VK_PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
  - device ID: 8086-3E92
  - API version: 1.1.95
