GPU-Z 2.17.0 released
Started by JeGX, February 27, 2019, 12:59:20 PM
Download:
- latest GPU-Z @ Geeks3D
- latest GPU-Z @ TPU
Changelog:
    Added support for NVIDIA GTX 1660 Ti, Titan RTX, RTX 2080 Mobile, RTX 2070 Mobile, RTX 2060 Mobile, Quadro RTX 4000, GTX 650 (GK106), Quadro P5200
    Added support for AMD Radeon VII, Radeon HD 8400E
    Added support for Intel Amber Lake GT2 (Core i7-8500Y)
    Added support for detection of Radeon Adrenalin 2019 version
    Simplified some sensor titles: "GPU Clock", "Memory Clock", "Shader Clock"
    Unified "Memory Used" / "Memory Usage" sensor titles to "Memory Used"
    Improved crash reporter to ask for problem description and optional email, so we can follow up
    Advanced Panel dropdown will show "Memory Timings" option only when memory timing details are available
    OpenCL "Max Packet Size" is now formatted as unsigned value
    Instead of empty value show "None" when no OpenCL Built-in Kernels supported
    Added support for "None" in OpenCL DP, SP, Half FP Capability
    Fixed "File creation failed" message during GPU-Z startup
    Fixed GPU and memory load monitoring on RX 580 2048 SP
    Fixed missing default boost clock on GTX 1660 Ti and some Pascal cards
    Fixed missing fan sensors on RTX cards with no monitor connected
    Fixed crash on startup (Windows XP)
    Fixed crash when opening DXVA 2.0 report (Windows XP)
    Fixed power limit reporting on older NVIDIA cards
    Fixed crash during BIOS save on older NVIDIA cards
    Fixed incorrect VRAM reporting on 16 GB Vega
    Fixed various crashes caused by physical memory access
via: https://www.techpowerup.com/253107/techpowerup-releases-gpu-z-v2-17-0
GPU-Z 2.17.0 + GeForce GTX 1080
