Author Topic: NVIDIA GeForce driver 418.43 for Linux, FreeBSD and Solaris  (Read 769 times)
« on: February 22, 2019, 05:25:59 PM »
http://de.download.nvidia.com/XFree86/Linux-x86_64/418.43/NVIDIA-Linux-x86_64-418.43.run
http://us.download.nvidia.com/XFree86/FreeBSD-x86_64/418.43/NVIDIA-FreeBSD-x86_64-418.43.tar.gz
http://fr.download.nvidia.com/solaris/418.43/NVIDIA-Solaris-x86-418.43.run
  • Added support for the following GPU:
    • GeForce GTX 1660 Ti
      GeForce RTX 2070 with Max-Q Design
      GeForce RTX 2080 with Max-Q Design
  • Fixed a bug that would occasionally cause visual corruption on some Vulkan titles. This bug was particularly prevalent on DXVK titles.
  • Fixed a bug that caused vkCmdPushConstants to generate Xid 13 messages when executed with VK_SHADER_STAGE_ALL on a compute queue.
  • Added initial support for G-SYNC Compatible monitors.See the README for details.
  • Added support for stereo presentation in Vulkan.
  • Fixed a bug that could cause OpenGL applications to crash after repeated VT-switches.
  • Fixed a bug that could sometimes prevent PRIME displays from being selected in the display settings page of nvidia-settings.
  • NVIDIA Video Codec SDK 9.0
    A new release of the Video Codec SDK will be available in Q1 2019. For more information and early access sign-up, refer to https://developer.nvidia.com/nvidia-video-codec-sdk
    The main features available in this release are listed below:
    o Support for Turing NVENC/NVDEC.
    o The NVDECODE API (also known as the NVCUVID API) has been updated to support YUV 4:4:4 decoding for HEVC on Turing GPUs.
    o NvEncodeAPI has been updated to support HEVC B-frames on Turing GPUs.
    o NvEncodeAPI adds the capability to output the encoded bitstream, and motion vectors from motion estimation-only mode, to video memory. This avoids the overhead of copying the output from system to video memory for processing pipelines operating directly on video memory.
    o NvEncodeAPI now accepts CUarrays as input buffers. The SDK contains a sample application to demonstrate how to feed a Vulkan image to NVENC using the Vulkan-CUDA interop.
  • Added NVIDIA optical flow support.
    A new library libnvidia-opticalflow.so is included in the driver package. The NVIDIA optical flow library can be used for hardware-accelerated computation of optical flow vectors and stereo disparity values. The API header files, sample applications and documentation will be available in a separate Optical Flow SDK package in Q1 2019.
    For more information and early access sign-up, refer to https://developer.nvidia.com/opticalflow-sdk
  • Removed libnvidia-wfb.so from the driver package.This module was only used on X servers that did not provide their own implementation of libwfb, and all X.Org xserver versions now supported by the driver do so.
  • Updated the VDPAU driver to reject decoding to YUV 4:2:2 video surfaces.The NVIDIA VDPAU driver always produces YUV 4:2:0 content.Previously, the VDPAU driver implicitly converted a YUV 4:2:2 video surface to YUV 4:2:0 during decode.Now, the VDPAU driver will fail the decode request.
  • Optimized nvidia-installer to only run depmod(1) once when installing, rather than twice (once during the uninstall phase and again when installing new kernel modules).
  • Removed the NVreg_UseThreadedInterrupts kernel module parameter from nvidia.ko. This removes the ability to forcibly fall back to an older mechanism (tasklets) for running the bottom-half interrupt handler. Instead, threaded IRQs (the default since 367.44) are always used.
  • Fixed a bug where destroying a direct-to-display swapchain could crash Vulkan applications.
  • Fixed a bug that prevented Vulkan applications from using the VK_EXT_display_control extension on a display that is driven by X.
  • Improved nvidia-bug-report.sh to grab the output of the `vulkaninfo` command when it is available.
  • Fixed build failures which resulted in errors like "implicit declaration of function drm_...", when building the NVIDIA DRM kernel module for Linux kernel 5.0 release candidates.
  • Fixed a bug that could prevent nvidia-xconfig from disabling the X Composite extension on version 1.20 of the X.org X server.
  • Fixed a build failure, "too many arguments to function 'get_user_pages'", when building the NVIDIA kernel module for Linux kernel v4.4.168.
  • Fixed a build failure, "implicit declaration of function do_gettimeofday", when building the NVIDIA kernel module for Linux kernel 5.0 release candidates.
