Author Topic: [Fixed] Seascape corruptions.  (Read 9052 times)
Dorian
  • Jr. Member
« on: February 14, 2019, 10:29:45 AM »
There is a issue on recent Intel graphics (SKL+) on seascape demo.
Screenshot (occurs after couple of seconds): https://imgur.com/a/TiTj1dz
The reason is a float overflow if order of operations is changed by shader compiler.
There is a simple workaround for this by changing one dot operation to use precise float.
Instead of using:
float hash(vec2 p)
    float h = dot(p, vec2(127.09999847412109375, 311.70001220703125));
    return fract(sin(h) * 43758.546875);
This can be used
float dot_precise(vec2 a, vec2 b)
    precise float result = 0;
    result += a.x * b.x;
    result += a.y * b.y;
    return result;
float hash(vec2 p)
    float h = dot_precise(p, vec2(127.09999847412109375, 311.70001220703125));
in s01-ps.frag.
« Last Edit: March 27, 2019, 01:23:24 PM by Dorian »
Re: Seascape corruptions.
« Reply #1 on: February 18, 2019, 01:24:50 PM »
Thanks!
I will update the shader in GPU Caps Viewer (and in the Shadertoy demopack)
Dorian
  • Jr. Member
« Reply #2 on: March 27, 2019, 01:22:56 PM »
Thank you JeGX,
I confirm it's fixed in Caps Viewer 1.42.0. :)
