Author Topic: NVIDIA Vulkan developer driver 417.63  (Read 1917 times)
« on: January 06, 2019, 09:38:41 AM »
 Windows driver version 417.63 and Linux driver version 415.22.05 provide new features for Vulkan developers to test their upcoming Vulkan applications.
 Windows 417.63
   Linux 415.22.05
   Release Updates   January 6th, 2019 - Windows 417.63, Linux 415.22.05
Re: NVIDIA Vulkan developer driver 417.63
« Reply #1 on: January 07, 2019, 09:21:08 AM »
I don't know why, but NVIDIA Vulkan drivers always doubles the number of graphics cards (with official GeForce drivers there's no problem). On my system, I have a RTX 2070 + GT 1030 and both the new GPU Shark 2 and Vulkan Caps Viewer see 4 GPUs:
GPU Shark 2 + NVIDIA Vulkan drivers + RTX 2070 + GT 1030
Vulkan Caps Viewer + NVIDIA Vulkan drivers + RTX 2070 + GT 1030
NVIDIA Vulkan developer driver 417.63 - VK_EXT_pci_bus_info
« Reply #2 on: January 07, 2019, 09:24:00 AM »
A quick test of VK_EXT_pci_bus_info (log from GeeXLab).
First GPU: RTX 2070
09:19:28:001(0000127)   [info ]   [Vulkan] - GPU name: GeForce RTX 2070
09:19:28:001(0000128)   [info ]   [Vulkan] - DeviceID: 10DE-1F02
09:19:28:001(0000129)   [info ]   [Vulkan] - NVIDIA driver version: 417.63_0.0
09:19:28:001(0000130)   [info ]   [Vulkan] - Vulkan API version: 1.1.96
09:19:28:001(0000131)   [info ]   [Vulkan] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
09:19:28:001(0000132)   [info ]   [Vulkan] - VK_EXT_pci_bus_info:
09:19:28:001(0000133)   [info ]   [Vulkan]   - pciDomain => 0
09:19:28:001(0000134)   [info ]   [Vulkan]   - pciBus => 1
09:19:28:001(0000135)   [info ]   [Vulkan]   - pciDevice => 0
09:19:28:001(0000136)   [info ]   [Vulkan]   - pciFunction => 0
Second GPU: GT 1030
09:19:28:002(0000143)   [info ]   [Vulkan] - GPU name: GeForce GT 1030
09:19:28:002(0000144)   [info ]   [Vulkan] - DeviceID: 10DE-1D01
09:19:28:002(0000145)   [info ]   [Vulkan] - NVIDIA driver version: 417.63_0.0
09:19:28:002(0000146)   [info ]   [Vulkan] - Vulkan API version: 1.1.96
09:19:28:002(0000147)   [info ]   [Vulkan] - Device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
09:19:28:002(0000148)   [info ]   [Vulkan] - VK_EXT_pci_bus_info:
09:19:28:002(0000149)   [info ]   [Vulkan]   - pciDomain => 0
09:19:28:002(0000150)   [info ]   [Vulkan]   - pciBus => 2
09:19:28:002(0000151)   [info ]   [Vulkan]   - pciDevice => 0
09:19:28:002(0000152)   [info ]   [Vulkan]   - pciFunction => 0
NVIDIA Vulkan developer driver 417.63 - RTX 2070 extensions
« Reply #3 on: January 07, 2019, 09:28:35 AM »
Tested on Windows 10 64-bit v1809
- Device 1
  - name: GeForce RTX 2070
  - device type: VK_PHYSICAL_DEVICE_TYPE_DISCRETE_GPU
  - device ID: 10DE-1F02
  - API version: 1.1.96
  - NVIDIA driver version: 417.63.0.0
  - # of extensions => 84
  - 001/ VK_KHR_8bit_storage
  - 002/ VK_KHR_16bit_storage
  - 003/ VK_KHR_bind_memory2
  - 004/ VK_KHR_create_renderpass2
  - 005/ VK_KHR_dedicated_allocation
  - 006/ VK_KHR_depth_stencil_resolve
  - 007/ VK_KHR_descriptor_update_template
  - 008/ VK_KHR_device_group
  - 009/ VK_KHR_draw_indirect_count
  - 010/ VK_KHR_driver_properties
  - 011/ VK_KHR_external_fence
  - 012/ VK_KHR_external_fence_win32
  - 013/ VK_KHR_external_memory
  - 014/ VK_KHR_external_memory_win32
  - 015/ VK_KHR_external_semaphore
  - 016/ VK_KHR_external_semaphore_win32
  - 017/ VK_KHR_get_memory_requirements2
  - 018/ VK_KHR_image_format_list
  - 019/ VK_KHR_maintenance1
  - 020/ VK_KHR_maintenance2
  - 021/ VK_KHR_maintenance3
  - 022/ VK_KHR_multiview
  - 023/ VK_KHR_push_descriptor
  - 024/ VK_KHR_relaxed_block_layout
  - 025/ VK_KHR_sampler_mirror_clamp_to_edge
  - 026/ VK_KHR_sampler_ycbcr_conversion
  - 027/ VK_KHR_shader_atomic_int64
  - 028/ VK_KHR_shader_draw_parameters
  - 029/ VK_KHR_shader_float16_int8
  - 030/ VK_KHR_shader_float_controls
  - 031/ VK_KHR_storage_buffer_storage_class
  - 032/ VK_KHR_swapchain
  - 033/ VK_KHR_swapchain_mutable_format
  - 034/ VK_KHR_variable_pointers
  - 035/ VK_KHR_vulkan_memory_model
  - 036/ VK_KHR_win32_keyed_mutex
  - 037/ VK_EXT_blend_operation_advanced
  - 038/ VK_EXT_buffer_device_address
  - 039/ VK_EXT_conditional_rendering
  - 040/ VK_EXT_conservative_rasterization
  - 041/ VK_EXT_depth_range_unrestricted
  - 042/ VK_EXT_descriptor_indexing
  - 043/ VK_EXT_discard_rectangles
  - 044/ VK_EXT_external_memory_host
  - 045/ VK_EXT_hdr_metadata
  - 046/ VK_EXT_inline_uniform_block
  - 047/ VK_EXT_memory_budget
  - 048/ VK_EXT_memory_priority
  - 049/ VK_EXT_pci_bus_info
  - 050/ VK_EXT_post_depth_coverage
  - 051/ VK_EXT_sample_locations
  - 052/ VK_EXT_sampler_filter_minmax
  - 053/ VK_EXT_scalar_block_layout
  - 054/ VK_EXT_shader_subgroup_ballot
  - 055/ VK_EXT_shader_subgroup_vote
  - 056/ VK_EXT_shader_viewport_index_layer
  - 057/ VK_EXT_transform_feedback
  - 058/ VK_EXT_vertex_attribute_divisor
  - 059/ VK_NV_clip_space_w_scaling
  - 060/ VK_NV_compute_shader_derivatives
  - 061/ VK_NV_corner_sampled_image
  - 062/ VK_NV_dedicated_allocation
  - 063/ VK_NV_dedicated_allocation_image_aliasing
  - 064/ VK_NV_device_diagnostic_checkpoints
  - 065/ VK_NV_external_memory
  - 066/ VK_NV_external_memory_win32
  - 067/ VK_NV_fill_rectangle
  - 068/ VK_NV_fragment_coverage_to_color
  - 069/ VK_NV_fragment_shader_barycentric
  - 070/ VK_NV_framebuffer_mixed_samples
  - 071/ VK_NV_geometry_shader_passthrough
  - 072/ VK_NV_mesh_shader
  - 073/ VK_NV_sample_mask_override_coverage
  - 074/ VK_NV_representative_fragment_test
  - 075/ VK_NV_scissor_exclusive
  - 076/ VK_NV_shader_image_footprint
  - 077/ VK_NV_shader_subgroup_partitioned
  - 078/ VK_NV_shading_rate_image
  - 079/ VK_NV_viewport_array2
  - 080/ VK_NV_viewport_swizzle
  - 081/ VK_NV_win32_keyed_mutex
  - 082/ VK_NVX_device_generated_commands
  - 083/ VK_NVX_multiview_per_view_attributes
  - 084/ VK_NV_ray_tracing
