Author Topic: Intel Graphics BETA Driver for Windows 10 Version DCH 25.20.100.6448  (Read 1416 times)
 Detailed Description
  WARNING: Failure to read the below may result in system instability
These new drivers labeled as Windows DCH graphics drivers are not backward compatible with our previous graphics drivers that we're now labeling Legacy. This means if later you want to revert to a Legacy driver you will need to uninstall the driver via Windows Apps and Features and reboot the system before installing a Legacy driver. Failure to do so may result in minor to catastrophic issues on your system as well as system instability.
DO NOT use the INF / Have-Disk method to install or uninstall this driver as it bypasses the Intel installer designed to install these new drivers, thereby possibly resulting in minor to major system instability. For this reason, we're not providing the ZIP file for the next several driver releases while users transition to this new Microsoft driver platform.
For more information about DCH drivers, read here.
If you have read this and would like to download the driver for install, go here.
