Author Topic: Shadow of the Tomb Raider benchmark  (Read 17148 times)
« on: December 11, 2018, 02:35:43 AM »
Download here: https://store.steampowered.com/app/750920/Shadow_of_the_Tomb_Raider/
 Settings: DX12, 1080p, ultra high
  • Full Member
Re: Shadow of the Tomb Raider benchmark
« Reply #1 on: December 11, 2018, 12:26:13 PM »
@Stefan:
Hello, friend! :) Your GPU bound was ONLY 68% - it isn't normal - try to enable full screen EXCLUSIVE for almost full GPU usage. :)
All max settings except motion blur OFF and bloom OFF at 1920x1080@TAA with full screen exclusive
My result:
My PC specs: CPU i7-4790K@4.7GHz, 16GB RAM DDR3-2400, ASUS Z97-Pro Gamer, EVGA GF GTX 980 Ti SC+
« Reply #2 on: December 11, 2018, 08:30:08 PM »
- Core i7 8700K
- 16 GB DDR4 3000MHz
- MSI GeForce RTX 2070 Ventus (GeForce 417.23)
1920x1080, preset highest: 13870 frames, 88 FPS
Shadow of the Tomb Raider benchmark - GeForce RTX 2070
3840x2160, preset highest: 5447 frames, 35 FPS
  • Full Member
« Reply #3 on: December 12, 2018, 12:09:59 PM »
@Stefan and @JeGX:
I tested to see the difference of GPU bound between full screen (FS) non-exclusive and FS exclusive and... I get the difference is little.
- FS exclusive: 96% GPU bound
- FS non-exclusive: 94% GPU bound only?! weird... :D lol
Try to close other programs for higher GPU usage/bound (less CPU bottlenecked). ;)
« Last Edit: December 12, 2018, 12:33:28 PM by nuninho1980 »
« Reply #4 on: December 12, 2018, 05:47:10 PM »
@Stefan and @JeGX:
Ditto. Using exclusive mode makes 4% difference on my rig.If i'm bored on the holydays i try to find the bottleneck...
