Author Topic: NVIDIA Vulkan developer driver 417.23  (Read 1122 times)
« on: December 03, 2018, 05:34:49 PM »
 Windows driver version 417.23 and Linux driver version 415.18.04 provide new features for Vulkan developers to test their upcoming Vulkan applications.
 Windows 417.23
   Linux 415.18.04
   Release Updates   December 2nd, 2018 - Windows 417.23, Linux 415.18.04
NVIDIA developer driver 417.23 - Vulkan info / RTX 2070
« Reply #1 on: December 03, 2018, 06:39:40 PM »
GPU Caps Viewer + GeForce RTX 2070
Vulkan report from GPU Caps Viewer:
- Instance extensions: 12
  - VK_KHR_device_group_creation (version: 1)
  - VK_KHR_external_fence_capabilities (version: 1)
  - VK_KHR_external_memory_capabilities (version: 1)
  - VK_KHR_external_semaphore_capabilities (version: 1)
  - VK_KHR_get_physical_device_properties2 (version: 1)
  - VK_KHR_get_surface_capabilities2 (version: 1)
  - VK_KHR_surface (version: 25)
  - VK_KHR_win32_surface (version: 6)
  - VK_EXT_debug_report (version: 9)
  - VK_EXT_debug_utils (version: 1)
  - VK_EXT_swapchain_colorspace (version: 3)
  - VK_NV_external_memory_capabilities (version: 1)
- Instance layers: 2
  - VK_LAYER_NV_optimus (version: 1.1.92, impl: 1)
  - VK_LAYER_LUNARG_standard_validation (version: 1.0.92, impl: 1)
- Physical devices: 1
  - [Vulkan device 0]: GeForce RTX 2070 ------------------
    - API version: 1.1.92
    - vendorID: 4318
    - deviceID: 7938
    - driver version: 1749401600
    - NVIDIA driver version: 417.23
    - driver properties (VK_KHR_driver_properties):
      -> driver name: NVIDIA
      -> driver ID: VK_DRIVER_ID_NVIDIA_PROPRIETARY_KHR (4)
      -> driver conformance version: 1.1.2.2:
      -> driver info: 417.23
  - memory heap count: 2
    - heap1: 8030MB
    - heap2: 8157MB
  - memory type count: 4
    - mem type 7 - heap index : 0 - property flag : 1
      > mem property: VK_MEMORY_PROPERTY_DEVICE_LOCAL_BIT
    - mem type 8 - heap index : 0 - property flag : 1
    - mem type 9 - heap index : 1 - property flag : 6
      > mem property: VK_MEMORY_PROPERTY_HOST_VISIBLE_BIT
      > mem property: VK_MEMORY_PROPERTY_HOST_COHERENT_BIT
    - mem type 10 - heap index : 1 - property flag : 14
      > mem property: VK_MEMORY_PROPERTY_HOST_CACHED_BIT
  - extensions: 77
    - VK_KHR_8bit_storage (version: 1)
    - VK_KHR_16bit_storage (version: 1)
    - VK_KHR_bind_memory2 (version: 1)
    - VK_KHR_create_renderpass2 (version: 1)
    - VK_KHR_dedicated_allocation (version: 3)
    - VK_KHR_descriptor_update_template (version: 1)
    - VK_KHR_device_group (version: 3)
    - VK_KHR_draw_indirect_count (version: 1)
    - VK_KHR_driver_properties (version: 1)
    - VK_KHR_external_fence (version: 1)
    - VK_KHR_external_fence_win32 (version: 1)
    - VK_KHR_external_memory (version: 1)
    - VK_KHR_external_memory_win32 (version: 1)
    - VK_KHR_external_semaphore (version: 1)
    - VK_KHR_external_semaphore_win32 (version: 1)
    - VK_KHR_get_memory_requirements2 (version: 1)
    - VK_KHR_image_format_list (version: 1)
    - VK_KHR_maintenance1 (version: 2)
    - VK_KHR_maintenance2 (version: 1)
    - VK_KHR_maintenance3 (version: 1)
    - VK_KHR_multiview (version: 1)
    - VK_KHR_push_descriptor (version: 2)
    - VK_KHR_relaxed_block_layout (version: 1)
    - VK_KHR_sampler_mirror_clamp_to_edge (version: 1)
    - VK_KHR_sampler_ycbcr_conversion (version: 1)
    - VK_KHR_shader_atomic_int64 (version: 1)
    - VK_KHR_shader_draw_parameters (version: 1)
    - VK_KHR_shader_float16_int8 (version: 1)
    - VK_KHR_shader_float_controls (version: 1)
    - VK_KHR_storage_buffer_storage_class (version: 1)
    - VK_KHR_swapchain (version: 70)
    - VK_KHR_swapchain_mutable_format (version: 1)
    - VK_KHR_variable_pointers (version: 1)
    - VK_KHR_vulkan_memory_model (version: 2)
    - VK_KHR_win32_keyed_mutex (version: 1)
    - VK_EXT_blend_operation_advanced (version: 2)
    - VK_EXT_conditional_rendering (version: 1)
    - VK_EXT_conservative_rasterization (version: 1)
    - VK_EXT_depth_range_unrestricted (version: 1)
    - VK_EXT_descriptor_indexing (version: 2)
    - VK_EXT_discard_rectangles (version: 1)
    - VK_EXT_external_memory_host (version: 1)
    - VK_EXT_hdr_metadata (version: 1)
    - VK_EXT_inline_uniform_block (version: 1)
    - VK_EXT_post_depth_coverage (version: 1)
    - VK_EXT_sample_locations (version: 1)
    - VK_EXT_sampler_filter_minmax (version: 1)
    - VK_EXT_scalar_block_layout (version: 1)
    - VK_EXT_shader_subgroup_ballot (version: 1)
    - VK_EXT_shader_subgroup_vote (version: 1)
    - VK_EXT_shader_viewport_index_layer (version: 1)
    - VK_EXT_transform_feedback (version: 1)
    - VK_EXT_vertex_attribute_divisor (version: 3)
    - VK_NV_clip_space_w_scaling (version: 1)
    - VK_NV_compute_shader_derivatives (version: 1)
    - VK_NV_corner_sampled_image (version: 2)
    - VK_NV_dedicated_allocation (version: 1)
    - VK_NV_device_diagnostic_checkpoints (version: 2)
    - VK_NV_external_memory (version: 1)
    - VK_NV_external_memory_win32 (version: 1)
    - VK_NV_fill_rectangle (version: 1)
    - VK_NV_fragment_coverage_to_color (version: 1)
    - VK_NV_fragment_shader_barycentric (version: 1)
    - VK_NV_framebuffer_mixed_samples (version: 1)
    - VK_NV_geometry_shader_passthrough (version: 1)
    - VK_NV_mesh_shader (version: 1)
    - VK_NV_sample_mask_override_coverage (version: 1)
    - VK_NV_representative_fragment_test (version: 1)
    - VK_NV_scissor_exclusive (version: 1)
    - VK_NV_shader_image_footprint (version: 1)
    - VK_NV_shader_subgroup_partitioned (version: 1)
    - VK_NV_shading_rate_image (version: 3)
    - VK_NV_viewport_array2 (version: 1)
    - VK_NV_viewport_swizzle (version: 1)
    - VK_NV_win32_keyed_mutex (version: 1)
    - VK_NVX_device_generated_commands (version: 3)
    - VK_NVX_multiview_per_view_attributes (version: 1)
  - device layers: 1
  - device features:
    - robustBufferAccess: true
    - fullDrawIndexUint32: true
    - imageCubeArray: true
    - independentBlend: true
    - geometryShader: true
    - tessellationShader: true
    - sampleRateShading: true
    - dualSrcBlend: true
    - logicOp: true
    - multiDrawIndirect: true
    - drawIndirectFirstInstance: true
    - depthClamp: true
    - depthBiasClamp: true
    - fillModeNonSolid: true
    - depthBounds: true
    - wideLines: true
    - largePoints: true
    - alphaToOne: true
    - multiViewport: true
    - samplerAnisotropy: true
    - textureCompressionETC2: false
    - textureCompressionASTC_LDR: false
    - textureCompressionBC: true
    - occlusionQueryPrecise: true
    - pipelineStatisticsQuery: true
    - vertexPipelineStoresAndAtomics: true
    - fragmentStoresAndAtomics: true
    - shaderTessellationAndGeometryPointSize: true
    - shaderImageGatherExtended: true
    - shaderStorageImageExtendedFormats: true
    - shaderStorageImageMultisample: true
    - shaderStorageImageReadWithoutFormat: true
    - shaderStorageImageWriteWithoutFormat: true
    - shaderUniformBufferArrayDynamicIndexing: true
    - shaderSampledImageArrayDynamicIndexing: true
    - shaderStorageBufferArrayDynamicIndexing: true
    - shaderStorageImageArrayDynamicIndexing: true
    - shaderClipDistance: true
    - shaderCullDistance: true
    - shaderFloat64: true
    - shaderInt64: true
    - shaderInt16: true
    - shaderResourceResidency: true
    - shaderResourceMinLod: true
    - sparseBinding: true
    - sparseResidencyBuffer: true
    - sparseResidencyImage2D: true
    - sparseResidencyImage3D: true
    - sparseResidency2Samples: true
    - sparseResidency4Samples: true
    - sparseResidency8Samples: true
    - sparseResidency16Samples: true
    - sparseResidencyAliased: true
    - variableMultisampleRate: true
    - inheritedQueries: true
  - device limits
    - maxImageDimension1D: 32768
    - maxImageDimension2D: 32768
    - maxImageDimension3D: 16384
    - maxImageDimensionCube: 32768
    - maxImageArrayLayers: 2048
    - maxTexelBufferElements: 134217728
    - maxUniformBufferRange: 65536
    - maxStorageBufferRange: 4294967295
    - maxPushConstantsSize: 256
    - maxMemoryAllocationCount: 4096
    - maxSamplerAllocationCount: 4000
    - bufferImageGranularity: 1024
    - sparseAddressSpaceSize: 18446744073709551615
    - maxBoundDescriptorSets: 32
    - maxPerStageDescriptorSamplers: 1048576
    - maxPerStageDescriptorUniformBuffers: 1048576
    - maxPerStageDescriptorSampledImages: 1048576
    - maxPerStageDescriptorStorageImages: 1048576
    - maxPerStageDescriptorInputAttachments: 1048576
    - maxPerStageResources: 4294967295
    - maxDescriptorSetSamplers: 1048576
    - maxDescriptorSetUniformBuffers: 1048576
    - maxDescriptorSetUniformBuffersDynamic: 15
    - maxDescriptorSetStorageBuffers: 1048576
    - maxDescriptorSetStorageBuffersDynamic: 16
    - maxDescriptorSetSampledImages: 1048576
    - maxDescriptorSetStorageImages: 1048576
    - maxDescriptorSetInputAttachments: 1048576
    - maxVertexInputAttributes: 32
    - maxVertexInputBindings: 32
    - maxVertexInputAttributeOffset: 2047
    - maxVertexInputBindingStride: 2048
    - maxVertexOutputComponents: 128
    - maxTessellationGenerationLevel: 64
    - maxTessellationPatchSize: 32
    - maxTessellationControlPerVertexInputComponents: 128
    - maxTessellationControlPerVertexOutputComponents: 128
    - maxTessellationControlPerPatchOutputComponents: 120
    - maxTessellationControlTotalOutputComponents: 4216
    - maxTessellationEvaluationInputComponents: 128
    - maxTessellationEvaluationOutputComponents: 128
    - maxGeometryShaderInvocations: 32
    - maxGeometryInputComponents: 128
    - maxGeometryOutputComponents: 128
    - maxGeometryOutputVertices: 1024
    - maxGeometryTotalOutputComponents: 1024
    - maxFragmentInputComponents: 128
    - maxFragmentOutputAttachments: 8
    - maxFragmentDualSrcAttachments: 1
    - maxFragmentCombinedOutputResources: 16
    - maxComputeSharedMemorySize: 49152
    - maxComputeWorkGroupCount: [2147483647; 65535; 65535]
    - maxComputeWorkGroupInvocations: 1024
    - maxComputeWorkGroupSize: [1024; 1024; 64]
    - subPixelPrecisionBits: 8
    - subTexelPrecisionBits: 8
    - mipmapPrecisionBits: 8
    - maxDrawIndexedIndexValue: 4294967295
    - maxDrawIndirectCount: 4294967295
    - maxSamplerLodBias: 15.000000
    - maxSamplerAnisotropy: 16.000000
    - maxViewports: 16
    - maxViewportDimensions: [32768; 32768]
    - viewportBoundsRange: [-65536.000000 ; 65536.000000]
    - viewportSubPixelBits: 8
    - minMemoryMapAlignment: 64
    - minTexelBufferOffsetAlignment: 16
    - minUniformBufferOffsetAlignment: 64
    - minStorageBufferOffsetAlignment: 32
    - minTexelOffset: 4294967288
    - maxTexelOffset: 7
    - minTexelGatherOffset: 4294967264
    - maxTexelGatherOffset: 31
    - minInterpolationOffset: -0.500000
    - maxInterpolationOffset: 0.437500
    - subPixelInterpolationOffsetBits: 4
    - maxFramebufferWidth: 32768
    - maxFramebufferHeight: 32768
    - maxFramebufferLayers: 2048
    - framebufferColorSampleCounts: 15
    - framebufferDepthSampleCounts: 15
    - framebufferStencilSampleCounts: 31
    - framebufferNoAttachmentsSampleCounts: 31
    - maxColorAttachments: 8
    - sampledImageColorSampleCounts: 15
    - sampledImageIntegerSampleCounts: 15
    - sampledImageDepthSampleCounts: 15
    - sampledImageStencilSampleCounts: 31
    - storageImageSampleCounts: 15
    - maxSampleMaskWords: 1
    - timestampComputeAndGraphics: 1
    - timestampPeriod: 1.000000
    - maxClipDistances: 8
    - maxCullDistances: 8
    - maxCombinedClipAndCullDistances: 8
    - discreteQueuePriorities: 2
    - pointSizeRange: [1.000000 ; 189.875000]
    - lineWidthRange: [0.500000 ; 10.000000]
    - pointSizeGranularity: 0.125000
    - lineWidthGranularity: 0.125000
    - strictLines: 1
    - standardSampleLocations: 1
    - optimalBufferCopyOffsetAlignment: 1
    - optimalBufferCopyRowPitchAlignment: 1
    - nonCoherentAtomSize: 64
