Author Topic: NVIDIA GeForce 417.01 WHQL Graphics Drivers Released  (Read 552 times)
« on: November 26, 2018, 05:42:11 PM »
New features:
- Provides the optimal gaming experience for Darksiders III.
Fixed issues:
- Monitor refresh rates higher than 30 Hz cannot be applied on 4k monitors. [2423614]
- Frame Rate Limiter 2 may not work. [2423316]
- [Turing GPUs]: Event ID 14 error may occur if CSM is disabled in the system BIOS. [2434721]
- [GeForce TX 650]: Shadowplay recordings are corrupted. [2416982]
- [G-Sync]: G-sync may not disengage after exiting games. [2418574]
- [GeForce Experience][Ansel]: Ansel images appear incomplete when the resolution is set to 30x or greater. [2082395]
Open issues:
[GeForce GTX 1080Ti]: Random DPC watchdog violation error when using multiple GPUs on motherboards with PLX chips. [2079538]
- [Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
- Display corruption may occur on higher refresh rate DisplayPort monitors upon resume from sleep mode. [2438988]
- [G-Sync]: Random flickering occurs when connecting G-sync monitor + non-G-Sync HDMI monitor with G-Sync enabled. [2399845]
417.01 Desktop Downloads
- win10 64-bit @ Geeks3D
- win7/win8 64-bit @ Geeks3D
- win10 64-bit @ NVIDIA
- win7/win8 64-bit @ NVIDIA
416.94 Notebook Downloads
Same OpenGL 4.6 and Vulkan 1.1.84 support than previous 416.94
GPU Caps Viewer + GeForce RTX 2080
