JeGX's Higgledy-Piggledy GeeXLab Screenshots
Started by JeGX, September 25, 2018, 08:35:38 AM
baryluk
#21
Quote from: JeGX on September 01, 2020, 02:29:34 PM
Gerstner waves.
Vertex shader based:
GeeXLab demo - Gerstner waves
Compute shader based:
Really love, it. The Compute based one doesn't work for me:
GeeXLab v0.41.2.0 (Feb 17 2021@17:34:40)
info    ...
info    [OpenGL] GLX version: 1.4
info    [OpenGL] GLX_VENDOR (srv): SGI
info    [OpenGL] GLX_VERSION (svr): 1.4
info    [OpenGL] GLX_VENDOR (client): Mesa Project and SGI
info    [OpenGL] GLX_VERSION (client): 1.4
info    [OpenGL] GLX_RENDERER_VENDOR_ID_MESA: 4098
info    [OpenGL] GLX_RENDERER_DEVICE_ID_MESA: 29440
info    [OpenGL] GLX_RENDERER_VERSION_MESA: 20.3.4
info    [OpenGL] GLX_RENDERER_ACCELERATED_MESA: 1
info    [OpenGL] GLX_RENDERER_VIDEO_MEMORY_MESA: 4096 MB
info    [OpenGL] GLX_RENDERER_UNIFIED_MEMORY_ARCHITECTURE_MESA: NO
info    [OpenGL] GLX_RENDERER_VENDOR_ID_MESA: AMD
info    [OpenGL] GLX_RENDERER_DEVICE_ID_MESA: AMD Radeon (TM) R9 Fury Series (FIJI, DRM 3.40.0, 5.10.0-3-amd64, LLVM 11.0.1)
info    Gerstner Waves - Compute Shaders - demo started with an OpenGL 4.6 context.
info    Quick OpenGL information (use /glinfo for more limits):
info    GL_RENDERER: AMD Radeon (TM) R9 Fury Series (FIJI, DRM 3.40.0, 5.10.0-3-amd64, LLVM 11.0.1)
info    GL_VENDOR: AMD
info    GL_VERSION: 4.6 (Core Profile) Mesa 20.3.4
info    GL_SHADING_LANGUAGE_VERSION: 4.60
info    OpenGL version detected: 4.6
info    OpenGL extensions: 227
info    OpenGL hardware limits:
info      GL_MAX_VERTEX_ATTRIBS: 16
info      GL_MAX_VERTEX_UNIFORM_COMPONENTS: 16384
info      GL_MAX_FRAGMENT_UNIFORM_COMPONENTS: 16384
info      GL_MAX_TEXTURE_SIZE: 16384
info      GL_MAX_VIEWPORT_DIMS: 16384 16384
info      GL_MAX_TEXTURE_IMAGE_UNITS: 32
info      GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS: 192
info    Render window (Gerstner Waves - Compute Shaders) initialized (renderer type: OpenGL)
warn    GPU program particle_prog - Pixel shader info log: 0:1(10): error: the compatibility profile is not supported
error   GPU program particle_prog - Pixel shader error: 0:1(10): error: the compatibility profile is not supported
info    GPU program particle_prog info log:
I need to pass `MESA_GL_VERSION_OVERRIDE=4.6COMPA` environment value, to make it launch. Not sure why I need that, but I don't know how compatibility profiles really work.
The "Particle size" slider, doesn't look to be doing anything either - it doesn't show these shiny star-like points on the grid vertices.
Try to remove the compatibility keyword in shaders/pixel.glsl.
Replace
#version 150 compatibility
by
#version 150
It's probably a copy/paste from a very old shader...
baryluk
Quote from: JeGX on March 08, 2021, 02:16:39 PM
Replace
by
#version 150
Thanks, that fixed both the start of the benchmark, and the shiny "particles" now show up too.
I'm adding the support of ImNodes. It's a small node editor for Dear ImGui.
GeeXLab - ImNodes - node editor
