Author Topic: Total Commander 7.5 FINAL for Windows released  (Read 5410 times)
« on: September 09, 2009, 10:13:58 PM »
September 9, 2009: Total Commander 7.5 FINAL is available now! There are many new functions. The most important are:
    * Full Unicode support in most functions where it is possible, including FTP, ZIP packer, and plugin interfaces
    * Help file now by default in HTML format (CHM). The old HLP file is still available online
    * Support for file names longer than 259 characters (up to 1022) in most file operations
    * The current directory above the file lists can act as a clickable bar ("breadcrumb bar")
    * Protect the stored ftp passwords with a master password using AES256 encryption
    * Start Lister, compare by content or synchronize dirs directly via command line parameters
    * Comments (Ctrl+Z) can now have a max. length of 4095 characters, and support line breaks
    * Synchronize dirs: Option to synchronize also empty directories, option to copy just specific file properties (like the time)
    * Allow to use the Windows key for user-defined hotkeys
    * On 64-bit Windows, allow to use 64-bit shell extensions in local menu (context menu)
    * Copy files/directories to multiple target directories (or lnk files pointing to directories) in one operation
    * Quick search with search dialog: Show button which allows to show only files/dirs matching the filter
    * Choose different character encodings in Lister, full support for right to left text
    * New internal association system, e.g. for using Total Commander from a USB stick
