Author Topic: Rules of optimization (Humus)  (Read 1444 times)
« on: August 06, 2018, 10:55:30 AM »
Rules of optimization:
1 - Design for performance from day 1
2 - Profile often
3 - Be vigilant on performance regressions
4 - Understand the data
5 - Understand the HW
6 - Help the compiler
7 - Verify your assumptions
8 - Performance is everyone's responsibility
What you need is a performance culture. Understand that performance is a core feature of your product. Poor performance is poor user experience, or in the case of games, possibly unplayable and unshippable. When you design new systems, you need to think about performance from the start. Yes, you can hack away at prototypes and proof of concept implementations without being overly concerned about micro-optimizations. You can run with it for a while and get a feel for how things hold up. It’s fine, you don’t have all the answers at this point. But put some thought into what sort of workload it should be able to handle once it goes into production. Does it run fine with 100 items? How about 1,000? A million? Is it conceivable that there will be a million items? Don’t just integrate a prototype into mainline without first having thought about the scale it will run at eventually. The idea isn’t that you should optimize everything down to the last SIMD instruction and last byte of memory in the first pass. But you should prepare your solution to be able to operate at the intended scale. If the code will only ever need a handful of objects, don’t obsess over performance. Will there be hundreds? See if you can simplify your math. Maybe group things sensibly. Will there be thousands? You should probably make sure it operates in batches, think about memory consumption, access pattern and bandwidth, perhaps separate active and inactive sets, or hierarchical subdivision. Tens of thousands? Time to think about threading perhaps? Millions? Start counting cycles and you can essentially not have cache misses anymore.
Link: http://www.humus.name/index.php?page=News&ID=383
