Author Topic: MSI Kombustor v4 (0.6.3.1) mising dll?  (Read 18396 times)
2mg
« on: July 02, 2018, 04:22:20 PM »
"the program can't start because api-ms-win-shcore-scaling-l1-1-1.dll is missing"
Windows 7 SP1 x64. I have all the VCRedist installed.
Latest FurMark works properly.
Any help?
Re: MSI Kombustor v4 (0.6.3.1) mising dll?
« Reply #1 on: July 03, 2018, 11:52:10 AM »
I think it's related to the support of high-DPI screen I added in the last version. And it looks like this support is not available on Win7. I will look at this issue asap. Thanks for the feedback.
2mg
« Reply #2 on: July 03, 2018, 11:58:39 AM »
There's a few threads regarding that specific .dll/issue on the web and it's mostly in regards to coding indeed. FYI I do have 150% DPI + WXP Style scaling turned on. Didn't work off, though. Cheers!
« Reply #3 on: July 03, 2018, 12:53:39 PM »
I found the bug. The fix will be available later today.
2mg
« Reply #4 on: July 04, 2018, 02:50:06 PM »
That was fast, thank you.
CPU Burner won't start though, same dll issue.
Also, I don't think the app is DPI-aware (flag), but patch notes say it has some DPI scaling properties:
https://imgur.com/a/Kr26G7C <- 150% Scaling + WXP Style scaling. I tried disabling DPI scaling for the app, but nope.
Hope you can spare a bit more time into fixing CPU burner and perhaps scaling. Appreciate it!
« Reply #5 on: July 05, 2018, 09:34:13 AM »
I will look at the CPU burner, this tiny tool has not been updated since years!
« Reply #6 on: July 05, 2018, 01:12:39 PM »
I uploaded a new version 0.6.3.3 that should improve Windows 7 support. There is no way to disable the high-DPI scaling by code on Win7 so I removed the background image of the main user interface. I also recompiled the CPU Burner and it seems to run on Win7 now.
2mg
« Reply #7 on: July 05, 2018, 01:59:17 PM »
Thank you very very much!
sorbit_4
« Reply #8 on: January 28, 2019, 11:16:46 AM »
64bit
Can you make a 32bit version, because the same problem under Windows 7 x86?
Thank you in advanced.
Gabor Takacs
« Reply #9 on: January 29, 2019, 07:36:38 AM »
I'm working on a new update of Kombustor and the 32-bit version will be fixed as well.
