Author Topic: Furmark 1.20 crash on windows 2012 R2  (Read 1900 times)
gtherrien
« on: June 22, 2018, 09:35:42 PM »
the system have Windows 2012 R2 on a dual socket system.
1 1080TI  is installed with CPU 1 and 1 1080TI is installed with CPU 2.
if the benchmark is running on:
                                     GPU1 on CPU1, no issue
                                     GPU1 on CPU2, furmark crash after 20 minutes.
if the GPU1 on CPU 1 is removed, the GPU1 on CPU 2 has no issue.
Regards
Re: Furmark 1.20 crash on windows 2012 R2
« Reply #1 on: June 26, 2018, 08:45:52 AM »
Not an easy answer... A PSU-related issue maybe?
gtherrien
« Reply #2 on: June 26, 2018, 03:25:15 PM »
i have same issue on 2 model of system. they are using 2000W on 208v.
3d mark and passmark burnin dont have any issue.
