Author Topic: GPU Caps Viewer 1.39.0.0 released  (Read 6691 times)
« on: May 15, 2018, 11:39:37 AM »
GPU Caps Viewer 1.39.0.0 is available.
Release notes and downloads:
https://www.geeks3d.com/20180515/gpu-caps-viewer-1-39-0-released/
Version 1.39.0.0 - 2018.05.15
+ added command line option to disable log file: /no_logfile
+ added minimal high-DPI support. GPU Caps Viewer is no
  longer scaled (blurry effect) with high DPI systems.
+ added NVIDIA TITAN V and Quadro GV100.
+ added AMD Radeon RX Vega 11, Vega 8 GPUs.
! the report file name now contains the report date and time
  (ex: _report_20180515.093517.txt). A new command line
  param allows to control this feature: /append_timestamp_to_report=0|1
* fixed a bug in the report export via command line.
! updated a bit the OpenGL panel.
! updated Intel GPUs information.
! updated: GPU Shark 0.11.2.0
! updated with latest GeeXLab SDK libs.
! recompiled with latest Vulkan API headers (v1.1.70).
! updated: ZoomGPU 1.21.7 (GPU monitoring library).
« Last Edit: November 01, 2018, 06:10:59 PM by JeGX »
Re: GPU Caps Viewer 1.39.0.0 released
« Reply #1 on: May 15, 2018, 08:36:04 PM »
Unfortunately GPUShark looks worse than before.Scaling at 100%
The GPU name flows out of the box because the font is too big.
« Reply #2 on: May 16, 2018, 03:04:24 PM »
TEST TEST and TEST before shipping any piece of code!!!
Go back home GPU Shark, I will fix your face!
Thanks Stefan  ;)
faisalgulfam32
« Reply #3 on: August 03, 2018, 12:34:54 PM »
Unable to retrieve performance scores after execution of all subtests on windows. Creation of csv file is working good but no scores are exported on AMD GPU's.
