GeeXLab 0.22.1.0 is now available for all platforms (Windows, Linux, macOS, Raspberry Pi and Tinker Board).
Downloads:
http://www.geeks3d.com/geexlab/downloads/Release notes:
http://www.geeks3d.com/hacklab/20180419/geexlab-0-22-1-released-for-all-platforms/Version 0.22.1.0 - 2018.04.12
+ added new built-in mesh: icosphere (gh_mesh.create_icosphere()).
! updated bounding volume management.
+ added bounding_volume_set_radius(), bounding_volume_set_aabb_min() and
bounding_volume_set_aabb_max() to gh_object lib (lua, python).
+ added draw_primitives() to gh_renderer lib (lua, python).
+ added create_actor_mesh_v2() to gh_physx3 lib (lua, python) to handle
convex meshes.
+ added create_actor_capsule() to gh_physx3 lib (lua, python).
! updated enable_state() / disable_state() of gh_renderer lib with
"GL_PROGRAM_POINT_SIZE".
+ [LINUX] added LuaJIT support.
Version 0.22.0.5 - 2018.03.29
! recompilation, some PhysX 3 functions were broken.
Version 0.22.0.4 - 2018.03.28
+ added actor_set_kinematic_target_v2() to gh_physx lib (lua, python)
Version 0.22.0.3 - 2018.03.28
! updated all gh_object.get_absolute_xxxxx() functions (position, orientation)
with the new mode 3 (set_absolute_transform_update_mode).
+ added a new mode (3) to set_absolute_transform_update_mode().
Version 0.22.0.2 - 2018.03.26
! plugin loading: the log file now contains information about plugins that are present.
Information about missing plugins is no longer in the log file.
! minor internal changes.
Version 0.22.0.1 - 2018.03.25
+ added set_absolute_transform_update_mode() to gh_object (lua, python)
Version 0.22.0.0 - 2018.03.25
+ added new library: gh_sqlite3 (lua, python).
+ added LuaSQL with SQLite3 driver (lua only).
+ added menu_begin_main_bar(), menu_end_main_bar(), menu_begin_bar(), menu_end_bar()
menu_begin(), menu_end() and menu_item() to gh_imgui lib (lua, python).
+ added get_uptime() to gh_utils lib (lua, python)
! updated the ImGuizmo library. All gh_imgui.gizmo_xxxxxx() functions
are now back (lua, python).
