Author Topic: NVIDIA Forceware 186.06 Beta available  (Read 12091 times)
« on: June 04, 2009, 04:43:33 PM »
Changes in Version 186.08
The following sections list the changes made and issues resolved since driver version
185.85.
The NVIDIA bug number is provided for reference.
Fixed Issues–Windows Vista 32-bit
Single GPU Resolved Issues
•GeForce 200 Series: Applying 16x anisotropic filtering from the NVIDIA Control
Panel does not result in sufficient improvement in 3D games. [549801]
•GeForce 7600GS: There is no audio thru the SPDIF. [406176]
•GeForce 6100/6150: Flat panel settings cannot be changed with Clone mode enabled.
[485979]
Multi-GPU Resolved Issues
•[SLI]: The PhysX option is disabled by default after driver installation. [544945]
•[SLI], GeForce GTX 280: Empire: Total War–flashing or corruption occurs for a few
seconds after any loading screen. [536648]
Windows Vista 64-bit Issues
Get it from NVIDIA
