Author Topic: NVIDIA GeForce GTX 1070 Ti  (Read 5930 times)
« on: September 29, 2017, 01:31:55 PM »
According to latest news, NVIDIA plans to launch (end of October 2017) a new Pascal-based graphics card: the GTX 1070 Ti.
Possible specs:
- GP104 GPU
- 2432 CUDA cores
- 8GB GDDR5
- around $400
- videocardz.com
- nordichardware.se
Re: NVIDIA GeForce GTX 1070 Ti
« Reply #1 on: October 09, 2017, 04:39:10 PM »
MSI Afterburner 4.4.0 Beta 19
Added core voltage control for reference design NVIDIA GeForce GT 1070 Ti series graphics cards
« Reply #2 on: October 10, 2017, 09:06:17 AM »
Guru3D striked the "Ti" from change log. Either a typo or they spoilt NVIDIA's surprise  :P
« Reply #3 on: October 12, 2017, 09:37:03 PM »
 Forget Afterburner, here is a log file from actual GTX 1070 Ti test  ;)
                 gpu 0  dev.sub 0.0
PCI Location   : 0x00, 0x01, 0x00, 0x00
DID            : 0x1b82
Raw ECID       : 0x00000000008023000000003054481991
Raw ECID (GHS) : 0x0000000164305448180000000c010100
ECID           : PC5H86-12_x02_y04
Device Id      : GP104
Revision       : a1
NV Base        : 0xf6000000
FB Base        : 0xe0000000
IRQ            : 16
NV_PMC_INTR_0 bit 30 high.
Trying to clear interrupt by writing 0x2 to register 0x12004c
Successfully cleared GPU's interrupt state.
Raw ECID (RM)  : 0
Foundry        : TSMC
Subsystem VID  : 0x10de
Subsystem DID  : 0x****
Board ID       : 0xed46
Chip SKU       : 300-0
Project        : G411-0010
Fuse File Fmt  : JSON
Display        : 0x000100
VGA adapter    : Primary
Native Mode    : 1280x1024
Memory Size    : 8192 MB
RAM Protocol   : GDDR5
RAM Config     : 1
ROM Version    : 86.04.84.00.01
ROM Type       : NVIDIA Authenticated
ROM Timestamp  : 2017-9-6 19:22:54
PState (mode)  : 8 5 2 [0]
PState Version : 3.0
EDC            : Disabled
GPC Clock      : 1847.5/1838.4 MHz DEFAULT
DRAM Clock     : 4201.9/4201.9 MHz MPLL
Host Clock     : 571.4/571.4 MHz XCLKGEN3
XBar Clock     : 1784.5/1784.7 MHz DEFAULT
Sys Clock      : 1657.5/1658.0 MHz DEFAULT
Power Clock    : 540.0/540.0 MHz SPPLL0
Display Clock  : 1325.0/1325.0 MHz DISPPLL
NVVDD          : 1000 mV
GPC  Mask      : 0x0f (4 GPCs)
TPC  Mask      : [1f 1f 1f 1e] (19 TPCs)
FB   Mask      : 0x0f (4 FB Partitions)
ROP/L2 Mask    : [3 3 3 3] (8 ROP/L2s)
PES  Mask      : [7 7 7 7] (12 PESes)
FBIO Mask      : 0x0f (4 FBIO Partitions)
FBIO Shift Mask: 0x00
XP   Mask      : 0x03 (2 3gio Pads)
Nvdec Mask     : 0x01 (1 engine)
Nvenc Mask     : 0x03 (2 engines)
Gpu Temp       : 44 deg C
PEX Width, ASLM: 16 lanes, Not Supported
PEX Link Speed : 8.0 Gbit/s
PEX BandWidth  : 128.0 Gbit/s
ASPM, ASPM-CYA : (L0s/L1, Disabled)
ASPM L1SS, CYA : (Disabled, L1.1/L1.2)
LTR            : Enabled
RM Version     : rel/gpu_drv/r367/r367_00-1252
gputest.js     : 71
boards.js      : 7
BgLogger Print Thread starts 5000.000, flush
BgLogger Monitor Thread starts 1000.000 (Detached)
WARNING: Changing g_TestMode from 16 to 8!
Running test(s) on GP104 (gpu 0, DID: 0x1b82, PCI Dom Bus Dev Fun: 0x0000, 0x01, 0x00, 0x00)
