Author Topic: NVIDIA FleX 1.20 beta  (Read 12234 times)
« on: June 11, 2017, 07:16:46 PM »
1.2.0 (beta)
- New API to retrieve particle neighbor information, see NvFlexGetNeighbors()
- New API to support shape collision filtering, collision channels can be assigned to particles and shapes to specify which pairs collide, see NvFlexPhase
- New API to support per-shape plastic deformation, it is now possible to specify plastic creep and threshold coefficient on a per-shape basis (previous global settings), see NvFlexSetRigids()
- New API to selectively disable solver features, this can lead to improved performance, see NvFlexFeatureMode, replaces global FlexParams::fluid option
- New API to allow sub-range particle buffer updates, see NvFlexCopyDesc
- New API for asynchronous compute, see NvFlexInitDesc
- Fix for unnecessary synchronization when calling NvFlexMap() on a device buffer
- Fix numerical precision for shape-matching constraints with large coordinates
- Fix for uninitialized contact indices returned from NvFlexGetContacts() if NvFlexUpdateSolver() has not been called
- Fix for SDF collision in D3D12
- Fix for D3D warning when using NvFlexSetRigids()
- Add D3D12 rendering support to the demo
- Add support for device NvFlexBuffers on D3D
- Enable NvToolkit profiling zones so to provide annotations in NSight profiles by default
Known Issues
- Demo rendering artifacts in D3D12 fullscreen on AMD platforms
- NvFlexGetTimers() may report incorrect values on D3D12
- Crash on inflatable test scenes on some Kepler class GPUs
« Last Edit: June 11, 2017, 07:19:08 PM by Stefan »
malcom123
Re: NVIDIA FleX 1.20 beta
« Reply #1 on: November 30, 2017, 11:29:36 AM »
Hello,
i am a beginner here, i can ask you if you have a link to download flex 1.2 beta ?
thank you
« Reply #2 on: November 30, 2017, 05:18:06 PM »
Hello,
thank you
There's a hyperlink in the first line.
You need to register both at https://github.com and https://developer.nvidia.com/gameworks beforehand.
malcom123
« Reply #3 on: November 30, 2017, 06:29:51 PM »
many thanks for answer... :)
but is not so easy.....
after register me on site
i was able only to download of Flex 0.80, 0.90, 1.00, 1.10
you have a recent direct link like this ?
https://developer.nvidia.com/auth0/callback?code=tN7FkQgExMLpDOLD&state=login&destination=/rdp/assets/flex110
(this link work only after login on https://developer.nvidia.com)
thanks Malcom
« Reply #4 on: November 30, 2017, 07:05:22 PM »
Don't know what's wrong on your rig, i re-checked the link and it's working fine.
I add a screenshot for reference.
Meanwhile there had been beta 2 released btw
1.2.0 (beta 2)
- NvFlexUpdateTriangleMesh() now takes vertices with 16-byte stride to remove CPU synchronization step in D3D implementations
- Fix for NvFlexGetTimers() reporting incorrect values on D3D12
- Fix for vsync in D3D12
- Fix for crash when using Flex with NVIDIA driver 384.76
Known Issues
- NVIDIA driver 384.94 can cause a crash on exit when D3D11 async compute is enabled. If using D3D11 with this driver, please disable async compute by setting runOnRenderContext=true in the NvFlexInitDesc you pass to FlexInit. D3D12 async compute is unaffected by the bug, and does not require this workaround.
malcom123
« Reply #5 on: December 01, 2017, 05:17:31 PM »
Another time many thanks, but on github is flex "Private" and with my user cannot access to specific repository.......
Have you possibility to make a mirror of demo Flex 1.2 (beta 2) (only win x64) ?
thanks
« Reply #6 on: December 01, 2017, 05:28:58 PM »
I forgot that you need an invitation.
Get it here
https://developer.nvidia.com/physx-source-github
Then you should see a lot of stuff at
https://github.com/NVIDIAGameWorks
malcom123
« Reply #7 on: December 02, 2017, 11:00:23 AM »
many thans, now works !!!!
« Reply #8 on: December 03, 2017, 11:39:53 AM »
I'm glad it worked for you  :)
Wow Stefan this looks really cool!
And bots are uncool  >:(
