Author Topic: AMD Crimson ReLive Edition 17.6.1  (Read 4334 times)
« on: June 09, 2017, 04:58:04 AM »
Radeon Software Crimson ReLive Edition 17.6.1 Highlights
Support For
    • DiRT 4™
      • Multi GPU profile
      • Up to 30% performance improvement when using 8xMSAA measured on Radeon RX 580 8GB graphics when compared to Radeon Software Crimson ReLive edition 17.5.2(1)
    • Prey®
      • Up to 4% performance improvement measured on Radeon RX 580 8GB graphics when compared to Radeon Software Crimson ReLive edition 17.5.2(2)
Fixed Issues
    • Virtual Super Resolution may fail to enable on some Radeon RX 400 and Radeon RX 500 series graphics products.
    • HDR may fail to enable on some displays for QHD or higher resolutions.
    • Flickering may be observed on some Radeon RX 500 series products when using HDMI® with QHD high refresh rate displays.
    • AMD XConnect: systems with Modern Standby enabled may experience a system hang after resuming from hibernation.
    • Fast mouse movement may cause an FPS drop or stutter in Prey® when running in Multi GPU system configurations.
    • Adjusting memory clocks in some third party overclocking applications may cause a hang on Radeon R9 390 Series products.
    • Graphics memory clock may fluctuate causing inconsistent frame rates while gaming when using AMD FreeSync technology.
    • Mass Effect™: Andromeda may experience stutter or hitching in Multi GPU system configurations.
    • The GPU Scaling feature in Radeon Settings may fail to enable for some applications.
    • Error message "Radeon Additional Settings: Host application has stopped working" pop up will sometimes appear when hot plugging displays with Radeon Settings open.
Re: AMD Crimson ReLive Edition 17.6.1
« Reply #1 on: June 09, 2017, 03:02:20 PM »
Radeon R9 290X:
