Author Topic: Notepad++ v5.4.2 available  (Read 12987 times)
« on: June 01, 2009, 04:46:17 PM »
Notepad++ v5.4.2 fixed bugs (from v5.4.1) :
1.  Fix the localization switcher bug while w/o doLocalConf.xml.
2.  Fix only one document "Move to other view" close Notepad++ instance issue.
3.  Fix plugin menu boolean check box bug.
Notepad++ v5.4.1 new features and fixed bugs (from v5.4) :
1.  Add ChangeMarkers plugin in installer.
2.  Add theme description in installer.
3.  Make installer update contextMenu.xml (backup the old one then override it with the new one).
4.  Fix lastRecentFileList localization issue.
5.  Add readonly change status notification for plugin system.
6.  Fix Styler Configurator user extension handler.
Get it from Sourceforge.
