Author Topic: Unity3D graphics API selector (for Windows)  (Read 9336 times)
« on: January 24, 2017, 11:11:19 PM »
As you might have already noticed Unity 5.6 supports now 7 different graphics APIs which you can build all together in one executable.
Unfortunately you can't select the API in the start window, so you have to use command line options.
Either manually or use following batch. Just replace name of executable.
@ECHO OFF
REM Courtesy of Stefan
SET game=Adventure_Sample_Game.exe
ECHO 1 - Vulkan
ECHO 2 - DX9
ECHO 3 - DX11
ECHO 4 - DX12
ECHO 5 - OpenGL
ECHO 6 - OpenGLES2
ECHO 7 - OpenGLES3
CHOICE /C:1234567
IF errorlevel 7 goto OpenGLES3
IF errorlevel 6 goto OpenGLES2
IF errorlevel 5 goto OpenGL
IF errorlevel 4 goto DX12
IF errorlevel 3 goto DX11
IF errorlevel 2 goto DX9
IF errorlevel 1 goto Vulkan
:Vulkan
ECHO Vulkan
%game% -force-vulkan
EXIT
:DX9
ECHO DX9
%game% -force-d3d9
EXIT
:DX11
ECHO DX11
%game% -force-d3d11
EXIT
:DX12
ECHO DX12
%game% -force-d3d12
EXIT
:OpenGL
ECHO OpenGL
%game% -force-opengl
EXIT
:OpenGLES2
ECHO OpenGLES2
%game% -force-gles20
EXIT
:OpenGLES3
ECHO OpenGLES3
%game% -force-gles30
EXIT
edit: code clean-up
« Last Edit: January 25, 2017, 12:03:23 AM by Stefan »
Re: Unity3D graphics API selector (for Windows)
« Reply #1 on: January 29, 2018, 12:27:26 PM »
DX9 has been removed from Unity 2017/2018, so i removed it from batch file as well.
@ECHO OFF
SET game="Adventure - Sample Game.exe"
ECHO 1 - Vulkan
ECHO 2 - DX11
ECHO 3 - DX12
ECHO 4 - OpenGL
ECHO 5 - OpenGLES2
ECHO 6 - OpenGLES3
CHOICE /C:123456
IF errorlevel 6 goto OpenGLES3
IF errorlevel 5 goto OpenGLES2
IF errorlevel 4 goto OpenGL
IF errorlevel 3 goto DX12
IF errorlevel 2 goto DX11
:Vulkan
ECHO Vulkan
EXIT
:DX11
ECHO DX11
%game% -force-d3d11
EXIT
:DX12
ECHO DX12
%game% -force-d3d12
EXIT
:OpenGL
ECHO OpenGL
EXIT
:OpenGLES2
ECHO OpenGLES2
EXIT
:OpenGLES3
ECHO OpenGLES3
EXIT
EmileTaw
« Reply #2 on: August 21, 2018, 02:27:17 PM »
Honestly, this should be built in already. But it's a simple solution I guess. Cheers, Stefan!
