Author Topic: EVGA GTX 1070/1080 Overheating Issues  (Read 7052 times)
« on: October 24, 2016, 06:54:13 PM »
So it seems like the EVGA series have got a hotspot, which reaches over 100 °C around the VRAM/VRM area (micron vram only allows up to~95°C). This leads to either the weird black screen bug or to combustion of certain modules around the area.
- Word of warning: The EVGA 1080 blackscreen/fan bug is based on a hotspot, which pretty much affects their whole pascal line @ reddit
- EVGA 1080 FTW Thermal imaging might explain black screen issues @ reddit
- Caution: EVGA 1070 and 1080 series cards may have a hardware fault  @ reddit
- Tom's Hardware test of the GTX 1080 FTW with FurMark
- EVGA reply on EVGA forums
“The test used in the referenced review from Toms Hardware (Germany) is running under Furmark, an extreme usage case, as most overclockers know. We believe this is a good approach to have some idea about the graphics card limit, and the thermal performance under the worst case scenario. EVGA has performed a similar qualification test during the design process, at a higher ambient temperature (30C in chamber) with a thermal coupler probe directly contacting the key components and after the Toms Hardware (Germany) review, we have retested this again. The results in both tests show the temperature of PWM and memory is within the spec tolerance under the same stress test, and is working as originally designed with no issues.
With this being said, EVGA understands that lower temperatures are preferred by reviewers and customers.
During our recent testing, we have applied additional thermal pads between the backplate and the PCB and between the baseplate and the heatsink fins, with the results shown below. We will offer these optional thermal pads free of charge to EVGA owners who want to have a lower temperature. These thermal pads will be ready soon; and customers can request them on Monday, October 24th, 2016.  Also, we will work with Toms Hardware to do a retest.”
Thanks,
EVGA
EVGA GeForce GTX 1080 FTW running FurMark with thermal pad mod (30C Ambient in Chamber) – October 21st, 2016
A damaged GTX 1070 FTW:
