Author Topic: TechPowerUp GPU-Z v1.12.0  (Read 3407 times)
« on: October 18, 2016, 04:54:55 PM »
GPU-Z is a lightweight utility designed to provide you with all information about your graphics card and GPU.
 Version History
 1.12.0
  • BIOS upload dialog will now let you browse to the uploaded or duplicate BIOS
  • NVIDIA Fermi DirectX support is now listed as 11.0
  • GTX 1050 & 1060: SLI support field now shows "Not supported by GPU"
  • Sensor window will now scroll by larger distance when clicking outside the thumbtrack
  • When GPU-Z window is at the right edge of screen, render test will open to the left of the GPU-Z window
  • Added DDR4 detection support for AMD Kaveri
  • Added support for NVIDIA GeForce GTX 1080 Mobile, GTX 1070 Mobile, GTX 1060 Mobile, GTX 1050 Ti, GTX 1050, 920 MX (GM108), 940 MX, Quadro P6000
  • Added support for AMD R9 M385X, R5 M315
  • Added support for Intel HD Graphics 620, HD Graphics 515
