Author Topic: Microsoft Visual C++ 2015 Redistributable Update 3  (Read 22207 times)
« on: August 21, 2016, 12:39:21 PM »
  • Microsoft Visual C++ 2015 Redistributable installs run-time components of Visual C++ libraries. These components are required to run C++ applications that are developed using Visual Studio 2015 Update 3 and link dynamically to Visual C++ libraries. The packages can be used to run such applications on a computer even if it does not have Visual Studio 2015 installed. These packages also install run-time components of C Runtime (CRT), Standard C++, MFC, C++ AMP, and OpenMP libraries.
    Microsoft Visual C++ 2015 Redistributable includes bug fixes to the runtime DLLs and also the latest versions for KB 2999226.
    To find out what's new in Visual Studio 2015 Update 3, see the Visual Studio 2015 Update 3 Release Notes. For a list of fixed bugs and known issues, see the Visual Studio 2015 Update 3 MSDN Article.
Re: Microsoft Visual C++ 2015 Redistributable Update 3
« Reply #1 on: August 24, 2016, 11:44:00 AM »
Downloads added:
- VS2015 Redistributable Update 3 (32-bit): http://www.geeks3d.com/dl/show/10044
- VS2015 Redistributable Update 3 (64-bit): http://www.geeks3d.com/dl/show/10045
juancarlos5893
« Reply #2 on: July 15, 2017, 12:58:25 AM »
Downloads added:
GRACIAS THANK YOU! JeGX
