NVIDIA ForceWare 190.57 OpenGL 3.2 Beta Drivers available
Started by Stefan, August 27, 2009, 02:57:22 PM
QuoteThis driver exposes the following new extensions:
For OpenGL 2.1 capable hardware:
    * ARB_fragment_coord_conventions (also in core OpenGL 3.2)
    * ARB_provoking_vertex (also in core OpenGL 3.2)
    * ARB_vertex_array_bgra (also in core OpenGL 3.2)
    * ARB_depth_clamp (also in core OpenGL 3.2)
For OpenGL 3 capable hardware:
    * WGL_ARB_create_context (updated to create profiles)
    * GLX_ARB_create_context (updated to create profiles)
    * GL_EXT_separate_shader_objects
    * GL_NV_parameter_buffer_object2
    * GL_NV_copy_image.txt
Added extension support for the following core features for OpenGL 3 capable hardware:
    * ARB_framebuffer_sRGB (also in core OpenGL 3.0)
    * ARB_texture_compression_rgtc (also in core OpenGL 3.0)
    * ARB_uniform_buffer_object (also in core OpenGL 3.1)
    * ARB_draw_element_base_vertex (also in core OpenGL3.2)
    * ARB_seamless_cube_map (also in core OpenGL3.2)
    * ARB_sync (also in core OpenGL3.2)
    * ARB_texture_multisample (also in core OpenGL3.2)
