GLEW 2.0.0 released
Started by Stefan, July 24, 2016, 07:03:36 PM
  • 2.0.0 [07-24-16]
    • Enhancements:
      • Forward context support added
      • OSMesa support added
      • EGL support added
      • MX support discontinued
      • Improved cmake build support
    • New extensions:
      • GL_AMD_shader_explicit_vertex_parameter
      • GL_ARB_gl_spirv
      • GL_EGL_NV_robustness_video_memory_purge
      • GL_EXT_window_rectangles
      • GL_INTEL_conservative_rasterization
      • GL_KHR_texture_compression_astc_sliced_3d
      • GL_MESA_shader_integer_functions
      • GL_NVX_blend_equation_advanced_multi_draw_buffers
      • GL_NVX_linked_gpu_multicast
      • GL_NV_clip_space_w_scaling
      • GL_NV_command_list
      • GL_NV_conservative_raster_pre_snap_triangles
      • GL_NV_draw_vulkan_image
      • GL_NV_gpu_multicast
      • GL_NV_robustness_video_memory_purge
      • GL_NV_shader_atomic_float64
      • GL_NV_stereo_view_rendering
      • GL_NV_viewport_swizzle
      • GLX_EXT_libglvnd
      • GLX_NV_robustness_video_memory_purge
