NVIDIA GeForce driver 364.15 for Linux, FreeBSD and Solaris
Started by Stefan, April 06, 2016, 05:37:01 PM
Linux Display Driver - x86
Linux x64 (AMD64/EM64T) Display Driver
Linux 32-bit ARM Display Driver
FreeBSD Display Driver – x86
FreeBSD Display Driver – x64
Solaris Display Driver – x64/x86
  • Added support for the following GPUs:
    • Quadro M6000 24GB
  • Fixed several EGL driver interaction problems with resizing windows in Wayland.
  • Fixed a bug that caused some DRM PRIME configurations to fail when DRM KMS was enabled (i.e., nvidia-drm.ko's modeset kernel module parameter was set to "1").
  • Fixed a bug that could cause a kernel crash when VDPAU was used while DRM KMS was enabled.
  • Updated the libglvnd snapshot included in the NVIDIA driver package to libglvnd commit b7d75429677eecc00c3701aaa4deac1304bc51ff. This contains a new revision of the libglvnd ABI. The driver is not compatible with a libglvnd older than commit c5bcda3b848fe52d6ae6ef25c917431c06d62d27.
  • Limited the default concurrency level in nvidia-settings to 32, to avoid hitting the maximum tasks limit on systems with many CPUs.
