Author Topic: NVIDIA Inspector 1.9.7.6  (Read 9769 times)
« on: March 25, 2016, 11:47:51 PM »
>>>download now<<<
###       NVIDIA INSPECTOR - CHANGELOG      ###
NVIDIA Inspector - Version 1.9.7.6 (.NET Framework 2 or above)
- fixed image upload
NVIDIA Profile Inspector - Version 2.1.2.0 (.NET Framework 4 or above)
- nvidiaProfileInspector is now open source and licensed under MIT license.
  (https://github.com/Orbmu2k/nvidiaProfileInspector)
- there are also continues builds available outside of the update cycle of nvidiaInspector
  (https://ci.appveyor.com/project/Orbmu2k/nvidiaprofileinspector/build/artifacts)
- added option to include predefined settings to the exported nip file
- fixed when all string fields got persisted on apply changes even if no changes was made to them
- fixed when the import removes the predefined settings of a profile if they are not included in the nip file
- fixed clicking the refresh button may crash the application for some users
NVIDIA Inspector - Version 1.9.7.5 (.NET Framework 2 or above)
- removed obsolete profile settings jump list entry
- fixed cuda lib error
NVIDIA Profile Inspector - Version 2.1.1.1 (.NET Framework 4 or above)
- reverted back to default font
- fixed layout problems (hopefully)
NVIDIA Inspector - Version 1.9.7.4 (.NET Framework 2 or above)
- replaced old ROP calculation with new API call, this schould fix ROP count for Maxwell 2 cards with reduced L2 Cache
- increased unlocked UI clock limit for non boost states to fix error with memory clocks beyond 4000MHz
- improved max boost clock estimation for maxwell
- completely removed settings profile editor from main application, it is now deployed as standalone application
NVIDIA Profile Inspector - Version 2.1.1.0 (.NET Framework 4 or above)
- completely reworked settings engine backend
- removed update detection / autoupdate
- updated to latest available settings api R352
- added stereo setting name detection from driver lib (thx to DarkStarSword)
- default custom setting names are now embedded to the exe file, and can be extracted with command line switch "-createCSN"
- added some GSYNC settings to CSN
- profile export now exports only customized settings without the nvidia predefined settings
- profile import now resets the profile to current driver defaults before import
- changed framerate limiter value selection to predicted fps instead of the raw api value
- you can drag'n drop nip files or application shortcuts now
NB: screenshot upload seems to be broken, use TPU capture instead
« Last Edit: March 31, 2016, 05:41:03 PM by Stefan »
« Reply #1 on: March 31, 2016, 05:41:46 PM »
v1.9.7.6 available, OP updated
Re: NVIDIA Inspector 1.9.7.6
« Reply #2 on: April 11, 2016, 10:54:52 PM »
NVIDIA Profile Inspector is now open source
latest commit : added frame rate limiter v2 values
