Author Topic: Vulkan API specifications 1.0.4 released  (Read 324037 times)
Vulkan API specifications 1.1.94 released
« Reply #60 on: November 29, 2018, 01:56:18 PM »
Change log for November 25, 2018 Vulkan 1.1.94 spec update:
  * Update release number to 94.
Public Issues:
  * Use the terms "`texel block`" and "`texel block size`" instead of "`data
    element`" and "`element size`", and define "`element`" as an array slot.
    In addition to the terminology changes, retitled the <<texel-block-size,
    Representation and Texel Block Size>> section and added texel block size
    / no. of texels/block information to the
    <<features-formats-compatibility, Compatible Formats>> table. There is
    some additional work underway to make sure the compatibility language
    makes sense for all of uncompressed, compressed, and multiplanar formats
    (public issue 763).
  * Cleanup `VK_NV_ray_tracing` language (public issues 858, 859).
Internal Issues:
  * Specify in <<shaders-invocationgroups, Invocation and Derivative
    Groups>> and <<textures-output-format-conversion, Texel Output Format
    Conversion>> that derivative groups are quads when code:SubgroupSize >=
    4 (internal issue 1390).
  * Make the type of slink:VkDescriptorUpdateTemplateCreateInfo::pNext
    `const` following pattern for the other stext:Vk*CreateInfo structures
    (internal issue 1459).
  * Specify that flink:vkCmdClearAttachments executes as a drawing command,
    rather than a transfer command (internal issue 1463).
  * Update `VK_NV_ray_tracing` to use code:InstanceId instead of
    code:InstanceIndex.
New Extensions:
  * `VK_KHR_swapchain_mutable_format`
  * `VK_EXT_fragment_density_map`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/c24b84795f6c083df107d8639286881a23894679
Extensions
- VK_KHR_swapchain_mutable_format
- VK_EXT_fragment_density_map
« Last Edit: November 29, 2018, 02:01:43 PM by JeGX »
Vulkan API specifications 1.1.95 released
« Reply #61 on: December 03, 2018, 12:53:32 PM »
Change log for December 3, 2018 Vulkan 1.1.95 spec update:
  * Update release number to 95.
Public Issues:
  * Fix valid usage and XML issues found in public issues 789 and 790 for
    the `VK_EXT_debug_utils` extension (public pull request 794).
  * Replace references to `VK_NV_dedicated_allocation` with links to the
    corresponding slink:slink:VkMemoryDedicatedRequirements and
    slink:slink:VkMemoryDedicatedAllocateInfo structures in the description
    of elink:VkExternalMemoryFeatureFlagBits (public issue 801).
  * Fix miscellaneous minor markup and spelling issues in
    `VK_NV_ray_tracing` extension (public pull request 860).
  * Remove "returnedonly" from XML for
    slink:VkPhysicalDeviceInlineUniformBlockFeaturesEXT and
    slink:VkPhysicalDeviceVulkanMemoryModelFeaturesKHR (public issue 862).
Internal Issues:
  * Add to the description of the
    <<features-limits-maxComputeSharedMemorySize,
    pname:maxCompureSharedMemorySize>> feature to state the shared variables
    should be packed at least as tightly as std430 (internal issue 1386).
  * Fix and clarify various references to image and image view usage in
    flink:vkCmdBindShadingRateImageNV, flink:vkCmdBeginRenderPass, and
    slink:VkImageStencilUsageCreateInfoEXT (internal issue 1432).
  * Require that the slink:VkImage mipmap chain match the Android hardware
    buffer mipmap chain for slink:VkMemoryAllocateInfo (internal issue
    1479).
  * Fix the definition of slink:VkSwapchainCreateInfoKHR valid usage
    statement 01778 (Vulkan-ValidationLayers!15)
  * Fix descriptions of <<interfaces-builtin-variables-launchid,
    code:LaunchIDNV>> and <<interfaces-builtin-variables-launchsize,
    code:LaunchSizeNV>> to code:uvec3.
New Extensions:
  * `VK_KHR_shader_float16_int8`
  * `VK_KHR_shader_float_controls`
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/ef29cea94bba541fe1ec9ffc33f65af1268bacad
Extensions
- VK_KHR_shader_float16_int8
- VK_KHR_shader_float_controls
Vulkan API specifications 1.1.96 released
« Reply #62 on: December 18, 2018, 11:36:39 AM »
Change log for December 16, 2018 Vulkan 1.1.96 spec update:
  * Update release number to 96.
Public Issues:
  * Fix typo in `vk.xml` for `structextends` attribute of
    slink:VkPhysicalDeviceShadingRateImagePropertiesNV (public PR 870).
  * Fix links in optimized PDF output (public PR 879).
Internal Issues:
  * Add a link to GitHub contributors in the <<credits, Other Credits>>
    section (internal issue 808).
  * Clarify the behavior of command aliases described in the <<versions,Core
    Revisions>> and <<initialization-functionpointers, Command Function
    Pointers>> sections and the registry schema document with respect to
    whether they are or are not the same entry point, and what the behaviour
    of the ftext:vkGet*ProcAddr commands is for each alias (internal issue
    1462).
  * Update slink:VkPipelineShaderStageCreateInfo valid usage statements for
    writing to code:Layer and code:viewportIndex to apply to any vertex
    processing stage (internal issue 1475).
  * Make sparse image creation optional for Y'C~B~C~R~ formats in the
    <<features-required-format-support, Required Format Support>> section
    and the <<features-formats-requiring-sampler-ycbcr-conversion, Formats
    requiring sampler Y'C~B~C~R~ conversion for
    ename:VK_IMAGE_ASPECT_COLOR_BIT image views>> table (internal issue
    1476).
  * Modify the valid usage statement for
    flink:vkCmdDrawIndirectByteCountEXT::pname:vertexStride to use the
    pname:maxTransformFeedbackBufferDataStride limit rather than the
    pname:maxVertexInputBindingStride limit, which is a better match for
    transform feedback related operations (internal issue 1487).
  * Changed all members of slink:VkPhysicalDevicePCIBusInfoPropertiesEXT to
    have the `uint32_t` type. This is an imcompatible change to an EXT
    that's very recently released; although this is against usual Vulkan WG
    policy, we discussed and consider this an acceptable risk, but have
    polled the mesa-dev list in case there are use cases we missed (internal
    issue 1492).
  * Set spec vetsion to 1 for `VK_GOOGLE_hlsl_functionality1` and
    `VK_GOOGLE_decorate_string` in `vk.xml` (internal MR 2948).
  * Remove redundant valid usage statement `VkImageCreateInfo-pNext-02395`
    (internal MR 2950).
  * Add `check_spec_links.py` script, use it in Gitlab CI, and fix many
    minor markup issues discovered by the script (internal MR 2955).
  * Update `BUILD.md` to the current Ruby version (2.5.3), and make some
    corresponding updates to per-platform build instructions (internal MR
    2956).
  * Fix binding numbers and other details in
    flink:vkUpdateDescriptorSetWithTemplate.txt example code blocks
    (internal MR 2960).
  * Remove some nautovalidity="true" in `vk.xml` for NV extensions where
    it's clearly wrong (internal MR 2970).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/b557dd2167a5b2c92a03a69b34ff7a4431cca7ad
Vulkan API specifications 1.1.97 released
« Reply #63 on: January 08, 2019, 08:53:12 PM »
Change log for January 05, 2019 Vulkan 1.1.97 spec update:
  * Update release number to 97.
Public Issues:
  * Add a special case to the <<renderpass-compatibility, Render Pass
    Compatibility>> rules allowing single-subpass renderpasses to be
    compatible even if they have different resolve attachment references
    (public issue 835).
  * Fix the miss shader binding table record address rule in the
    <<shader-binding-table-indexing-rules, Miss Shaders>> section to index
    by code:missIndex, not code:sbtOffset (public issue 875).
Internal Issues:
  * Add a missing anchor to the elink:VkSamplerCreateFlagBits language
    (internal issue 1483).
  * Add missing implicit valid usage include for slink:VkHdrMetadataEXT and
    corresponding `noautovalidity` attributes in `vk.xml` for the
    externally-defined metadata properties (internal issue 1514).
  * Remove restrictions on the `mask` parameter of SPIR-V's
    code:OpGroupNonUniformXor in the <<spirvenv-module-validation,
    Validation Rules within a Module>> appendix (internal merge request
    2971).
  * Restore `noautovalidity` attribute for
    slink:VkPipelineViewportWScalingStateCreateInfoNV::pname:pViewportWScalings
    in `vk.xml` (internal merge request 2975).
  * Update copyright dates on Khronos-copyrighted files to 2019 (internal
    merge request 2980).
New Extensions:
  * `VK_KHR_depth_stencil_resolve`
  * `VK_EXT_buffer_device_address`
  * `VK_EXT_memory_budget`
  * `VK_EXT_memory_priority`
  * `VK_EXT_validation_features`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/56e0289318a4cd23aa5f5dcfb290ee873be53b82
New extensions:
- VK_KHR_depth_stencil_resolve
- VK_EXT_buffer_device_address
- VK_EXT_memory_budget
- VK_EXT_memory_priority
- VK_EXT_validation_features
Vulkan API specifications 1.1.98 released
« Reply #64 on: January 17, 2019, 08:39:08 AM »
Change log for January 13, 2019 Vulkan 1.1.98 spec update:
  * Update release number to 98.
Public Issues:
  * Fix missing markup in flink:vkDestroyPipelineLayout valid usage
    statement (pull request 882).
  * Add missing contributors for `<<VK_EXT_buffer_device_address>>` (public
    pull request 891).
Internal Issues:
  * Detect nested bullet points in valid usage blocks and warn about them
    during VUID assignment (internal issue 1382).
  * Update the style guide to document the process for reserving new bits in
    bitmask types (internal issue 1411).
  * Clarify for slink:VkApplicationInfo::pname:apiVersion and in the
    <<fundamentals-validusage-versions, Valid Usage for Newer Core
    Versions>> section when it is valid for an application to use a certain
    version of Vulkan API functionality (for an instance and for a
    device/physical device); and when the validation layers must generate an
    error (internal issue 1412).
  * Add optional <<memory-model-availability-visibility, transitive
    availability/visibility operations to the memory model, including a new
    pname:vulkanMemoryModelAvailabilityVisibilityChains feature for
    slink:VkPhysicalDeviceVulkanMemoryModelFeaturesKHR (internal issue
    1460).
  * Add the code:StorageBuffer storage class to those in the
    <<interfaces-resources-descset, Descriptor Set Interface>> (internal
    issue 1480).
  * Add missing `returnedonly` tags for a number of returned extension
    structures that can be passed in pname:pNext chains (internal issue
    1515).
  * Clean up and rearrange some spec language for
    slink:VkRenderPassCreateInfo and slink:VkAttachmentReference.txt
    (internal issue 1522).
  * Correctly round the code:OpVectorTimesScalar and
    code:OpMatrixTimesScalar SPIR-V operations in the <<Precision of core
    SPIR-V Instructions>> table (internal merge request 2996).
  * Work around cases in flink:vkCmdBeginTransformFeedbackEXT,
    flink:vkCmdEndTransformFeedbackEXT, and
    slink:VkPipelineCoverageModulationStateCreateInfoNV where an array
    parameter is `optional` but the length is not in `vk.xml`. This is an
    interim fix using `noautovalidity` + handcoded VU replacing those that
    should be autogenerated (internal issue 2944 and
    KhronosGroup/Vulkan-ValidationLayers#480).
  * Remove redundant capability validation of the code:float16 and code:int8
    SPIR-V capabilities from the <<spirvenv-capabilities, Capabilities>>
    section, since they are already covered in the preceding table.
  * Update check_spec_links script, including validation for reference page
    open blocks. Fix errors identified by the script.
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/f1a7c4b4f3031f985396f1aa617c51fd8a01c8c8
Vulkan API specifications 1.1.99 released
« Reply #65 on: February 11, 2019, 04:50:07 PM »
Change log for February 3, 2019 Vulkan 1.1.99 spec update:
  * Update release number to 99.
Public Issues:
  * Add missing pname:pMemoryHostPointerProperties description to
    flink:vkGetMemoryHostPointerPropertiesEXT.txt (public pull request 896).
  * Minor markup fixes (public pull request 900).
  * Minor update to `khronos.css` and markup fixes (originally proposed in
    public pull request 901, but done via an internal MR).
Internal Issues:
  * Document restrictions on image queries for Y'CbCr formats in the
    <<features-formats-requiring-sampler-ycbcr-conversion>> table as well as
    for slink:sname:VkImageFormatProperties and slink:VkImageCreateInfo
    (internal issue 1361).
  * Correct type of the code:FragSizeEXT built-in in the
    <<interfaces-builtin-variables, Built-In Variables>> section (internal
    issue 1526).
  * Clean up math in the <<textures, Image Operations>> chapter by
    refactoring, using better naming conventions, updating diagrams to use
    the correct orientation, etc. (internal merge request 2968).
  * Fix minor typos for slink:VkImageCreateInfo and
    slink:VkImageStencilUsageCreateInfoEXT.
  * Add missing documentation for tlink:VkResolveModeFlagsKHR.
  * Fix extension dependency of pname:scalarBlockLayout in the
    <<features-features-requirements, Feature Requirements>> section.
  * Fix indexing math for shader binding table calculations in the
    <<shader-binding-table-indexing-rules, Indexing Rules>> section, and use
    spelling "`any-hit`" consistently.
  * Reconcile valid usage statement and text for sampled image layouts in
    slink:VkWriteDescriptorSet
    (KhronosGroup/Vulkan-ValidationLayers#551).
  * Make SPIR-V code:OpConvertUToPtr and code:OpConvertPtrToU operations
    require a 64-bit integer for physical storage buffer pointers in the
    <<spirvenv-module-validation, Validation Rules within a Module>>
    section.
  * Update to KaTeX 10.0.
New Extensions:
  * `VK_EXT_filter_cubic`
  * `VK_NV_dedicated_allocation_image_aliasing`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/b59ec03ee3f44086ebc3e4c556952afe9e743655
New extensions:
- VK_EXT_filter_cubic
- VK_NV_dedicated_allocation_image_aliasing
Vulkan API specifications 1.1.100 released
« Reply #66 on: February 11, 2019, 04:51:12 PM »
Change log for February 10, 2019 Vulkan 1.1.100 spec update:
  * Update release number to 100.
Public Issues:
  * Clarify that scoped modification order only relates to
    <<memory-model-atomic-operation, atomic writes>> (public pull request
    906).
  * Remove `readme.txt` reference from `xml/README.adoc` (public pull
    request 907).
  * Add missing slink:VkShaderResourceUsageAMD to the <<Vk_AMD_shader_info>>
    appendix (public pull request 908).
  * Fix markup for <<VK_EXT_filter_cubic>> appendix (public pull request
    911).
  * Fix typo "`attachment`" (public pull request 914).
  * Alias the enums for `VK_IMG_filter_cubic` properly to the corresponding
    `VK_EXT_filter_cubic` enums, so they appear in the corresponding
    enumerated types, instead of as #defines (Vulkan-Headers issue 40).
Internal Issues:
  * Remove nested conditionals in valid usage statements for
    slink:VkFramebufferCreateInfo and flink:vkCmdPipelineBarrier by
    duplicating statements along ifdef/ifndef paths for
    VK_KHR_depth_stencil_resolve (internal issue 1527).
  * Clarify allowed values of <<spirv-precision-operation, SPIR-V operations
    near infinity>>. For very large results of operations the allowed range
    of return values as defined in the spec didn't include the largest
    finite number. In some rounding modes (eg. RTZ) the largest finite
    number is the correctly rounded result, so it should be allowed.
  * Require descriptor types to match in slink:VkCopyDescriptorSet.
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/fcf5980cf6acc620334f55b0cf2d162b05e0487a
Vulkan API specifications 1.1.101 released
« Reply #67 on: February 19, 2019, 02:04:34 PM »
Change log for February 17, 2019 Vulkan 1.1.101 spec update:
  * Update release number to 101.
Public Issues:
  * Make clear that memory types for imported host memory must be host
    visible in slink:VkMemoryHostPointerPropertiesEXT.txt (public issue
    897).
  * Make <<interfaces-resources-layout, WARNING block>> into a NOTE block,
    per the styleguide (public pull request 916).
Internal Issues:
  * Make <<textures-output-format-conversion, computation of derivatives in
    non-uniform flow control>> have undefined behavior (internal issue
    1367).
  * Make behavior, not just values, undefined for
    <<textures-layout-validation, reads from inconsistent YCbCr layouts>>
    (internal issue 1366).
  * Consolidate version and extension behavior documentation in the
    <<extended-functionality, Extended Functionality>> appendix, While a
    great deal of text was moved from other parts of the Specification into
    the appendix, this just serves to simplify and make consistent
    discussions of versions and extensions (internal issue 1473).
  * Add limits for slink:VkPhysicalDeviceRayTracingPropertiesNV in the
    <<features-limits-types, Required Limit Types>> and
    <<features-limits-required, Required Limits>> tables (internal issue
    1511).
  * Disallow <<memory-protected-memory, indirect calls within protected
    command buffers>> by adding valid usage statements for the related
    indirect dispatch and draw commands (internal issue 1513).
  * Add valid usage stataements to slink:VkGraphicsPipelineCreateInfo,
    slink:VkSubpassDescription, slink:VkSubpassDescription2KHR,
    slink:VkSubpassDescriptionDepthStencilResolveKHR, and
    slink:VkImageViewCreateInfo preventing the creation of a renderpass with
    attachments in formats that are not supported for rendering (internal
    issue 1552).
  * Qualify valid usage statements for
    slink:VkAttachmentReference::pname:layout parameter so restrictions only
    apply if an attachment is ename:VK_ATTACHMENT_UNUSED (internal issue
    1561).
  * Add valid usage statement for flink:vkCmdDrawIndirectByteCountEXT
    restricting pname:vertexStride to be positive (internal issue 1566).
  * Make the `VK_EXT_sample_locations` extension depend on
    `VK_KHR_get_physical_device_properties2` in `vk.xml`.
  * Rearrange and simplify the <<interfaces-resources-layout, block layout
    rules>>.
New Extensions:
  * `VK_NV_cooperative_matrix`
  * `VK_EXT_depth_clip_enable` (internal issue 1485).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/55220784e078fe3dad80e9520ca1d264f9b12b72
New extensions:
- VK_NV_cooperative_matrix
- VK_EXT_depth_clip_enable
Vulkan API specifications 1.1.102 released
« Reply #68 on: March 04, 2019, 03:37:39 PM »
Change log for March 3, 2019 Vulkan 1.1.102 spec update:
  * Update release number to 102.
Public Issues:
  * Simplify flink:vkGetImageMemoryRequirements constraint for
    ename:VK_MEMORY_PROPERTY_LAZILY_ALLOCATED_BIT (public pull request 817).
  * Fix typo in markup of the <<textures-texel-coordinate-systems-diagrams,
    Texel Coordinate Systems, Corner Sampling>> image that was generating
    complaints from chunked HTML output generation (public pull request
    928).
Internal Issues:
  * Split the old <<features, Features>> chapter into four chapters:
    <<features, Features>>, <<limits, Limits>>, <<formats, Formats>>, and
    <<capabilities, Capabilities>>, with minor edits to the introductory
    paragraph of each chapter. Anchor names in these chapters were changed,
    with corresponding effects to xrefs to these anchors elsewhere in spec
    markup . The purpose is to make the chunked HTML spec output load faster
    on what was previously a single, gigantic chapter (internal issue 1554).
  * Add ename:VK_PIPELINE_STAGE_RAY_TRACING_SHADER_BIT_NV, to the supported
    pipeline stages for ename:VK_ACCESS_UNIFORM_READ,
    ename:VK_ACCESS_SHADER_READ, and ename:VK_ACCESS_SHADER_WRITE in the
    <<synchronization-access-types-supported>> table.
  * Correct legal name of Google, LLC in vk.xml \<tags> section and a
    copyright statement.
  * Clarify that Vulkan treats the Android
    code:AHARDWAREBUFFER_FORMAT_R8G8B8X8_UNORM format as RGBA, and the
    application is responsible for forcing the X/A component to be read as
    1.0, in the <<memory-external-android-hardware-buffer-formats>> table.
  * Clarify the vertex order of various primitive topologies, and define the
    order of transform feedback vertex capture based on that. This involves
    a lot of refactoring and cleanup in the <<drawing-primitive-topologies,
    Primitive Topologies>>, <<geometry-input, Geometry Shader Input
    Primitives>> sections, and <<vertexpostproc-transform-feedback Transform
    Feedback>> sections, and numerous places in the <<tessellation>>
    chapter,
New Extensions:
  * `VK_EXT_metal_surface`
  * `VK_EXT_ycbcr_image_arrays` (internal issue 1361).
  * `VK_NVX_image_view_handle`
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/35e7bee5f0f50b7c1634cd205ded035acea43ad9
New extensions:
- VK_EXT_metal_surface
- VK_EXT_ycbcr_image_arrays
- VK_NVX_image_view_handle
Vulkan API specifications 1.1.103 released
« Reply #69 on: March 17, 2019, 02:26:48 PM »
Change log for March 11, 2019 Vulkan 1.1.103 spec update:
  * Update release number to 103.
Public Issues:
  * Remove (unnecessary) scoped modification order case from the memory
    model <<memory-model-location-ordered, location-ordered>> definition
    (public pull request 924).
  * Add an <<memory-model-acyclicity, acyclicity>> axiom to the memory model
    (public pull request 927).
Internal Issues:
  * Fix reversed logic of slink:VkFormatProperties discussion of multi-plane
    formats and ename:VK_FORMAT_FEATURE_DISJOINT_BIT (internal issue 1493).
  * Clarify how slink:VkImageStencilUsageCreateInfoEXT works, including new
    valid usage statements for flink:vkCmdClearDepthStencilImage, and the
    <<copies, Common Operation>> section of the Copy Commands chapter
    (internal issue 1565).
  * Update <<spirvenv-precision-operation, Precision and Operation of SPIR-V
    Instructions>> section to require that denorms be preserved by several
    instructions that don't perform any mathematical operations (internal
    issue 1584).
  * Remove duplicate valid usage statement from flink:vkAcquireNextImageKHR
    (internal merge request 3062).
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/4ad4fd17161efd9bfd1125c0c9d17db6fb276216
Vulkan API specifications 1.1.104 released
« Reply #70 on: March 21, 2019, 03:09:06 PM »
Change log for March 18, 2019 Vulkan 1.1.104 spec update:
  * Update release number to 104.
Public Issues:
  * Remove the incorrect line from "`Initial`" to "`Invalid`" state in the
    <<commandbuffer-lifecycle-diagram, Lifecycle of a command buffer>>
    diagram (public issue 881).
  * Add Fuchsia platform to <<boilerplate-wsi-header-table, Window System
    Extensions and Headers>> table (public pull request 933).
  * Change the type of
    slink:VkBufferDeviceAddressCreateInfoEXT::pname:deviceAddress from
    basetype:VkDeviceSize to basetype:VkDeviceAddress. These are both
    typedefs of code:uint64_t, so it is an ABI-compatible change (public
    issue 934).
Internal Issues:
  * Remove generated header files and update the CI tests to build a copy of
    the headers for use by the hpp-generate / hpp-compile CI stages. Targets
    to generate the headers will not be removed, but keeping these generated
    files in the repository increased the frequency of conflicts between
    branches when merging to master (internal issue 745).
  * Reword "`undefined: behavior if *action*" to "`must: not do *action*`"
    in the places the old terminology was used, and add a new
    <<writing-undefined, Describing Undefined Behavior>> section of the
    style guide to explain how to write such language in the future
    (internal issue 1579).
  * Move almost all Python scripts into the toplevel `scripts/` directory.
    Apply extensive internal edits to clean up and simplify the scripts, and
    try to follow PEP8 guidelines. Generalize the scripts with the use of a
    Conventions object controlling many aspects of output generation, to
    enable their use in other Khronos projects with similar requirements.
    Autogenerate extension interface refpages (these are experimental and
    may be retired going forward).
New Extensions:
  * `VK_AMD_display_native_hdr`
  * `VK_EXT_full_screen_exclusive` (internal issue 1439)
  * `VK_EXT_host_query_reset`
  * `VK_EXT_pipeline_creation_feedback` (internal issue 1560)
  * `VK_KHR_surface_protected_capabilities` (internal issue 1520)
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/476e3f422dc251065c535c1d8a5cfc58f1cff3c9
New extensions:
- VK_AMD_display_native_hdr
- VK_EXT_full_screen_exclusive
- VK_EXT_host_query_reset
- VK_EXT_pipeline_creation_feedback
- VK_KHR_surface_protected_capabilities
Vulkan API specifications 1.1.105 released
« Reply #71 on: March 21, 2019, 03:12:54 PM »
Change log for March 19, 2019 Vulkan 1.1.105 spec update (GDC edition):
  * Update release number to 105.
Public Issues:
  * Fix contractions and other markup issues (public pull request 935).
New Extensions:
  * Google Games Platform
  ** New `ggp` platform and associated header file `vulkan_ggp.h`
  ** `VK_GGP_frame_token`
  ** `VK_GGP_stream_descriptor_surface`
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/0aca7bb22e616fe8f07a58c2e2c8e8c91ccaf5a2
New extensions:
- VK_GGP_frame_token
- VK_GGP_stream_descriptor_surface
Vulkan API specifications 1.1.106 released
« Reply #72 on: April 11, 2019, 05:49:03 PM »
Change log for April 7, 2019 Vulkan 1.1.106 spec update:
  * Update release number to 106.
Public Issues:
  * Add searchbox and generate search index for the chunked HTML target.
    Note that doing this requires several new toolchain components to build
    the `chunked` target (public issue 578 / internal issue 1352).
  * Remove descriptions of flink:vkCreateSampler sampler constraints which
    were repeated in the valid usage statements (public pull request 648).
  * Fix sense of conditional around a valid usage statement in the
    <<copies>> chapter (public issue 942).
Internal Issues:
  * Add missing pname:extent.width and pname:extent.height valid usage
    statements for flink:vkCmdClearAttachments (internal issue 1583).
  * Fix some inconsistencies in structures and corresponding pname:sType
    enumerant names by renaming
    sname:VkPhysicalDeviceShaderDrawParameterFeatures ->
    slink:slink:VkPhysicalDeviceShaderDrawParametersFeatures;
    sname:VkPhysicalDeviceVariablePointerFeatures ->
    slink:VkPhysicalDeviceVariablePointerFeatures;
    sname:VkPhysicalDeviceVariablePointerFeaturesKHR ->
    slink:VkPhysicalDeviceVariablePointerFeaturesKHR;
    sname:VkPhysicalDeviceBufferAddressFeaturesEXT ->
    slink:VkPhysicalDeviceBufferDeviceAddressFeaturesEXT;
    etext:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_SHADER_DRAW_PARAMETER_FEATURES
    ename:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_SHADER_DRAW_PARAMETERS_FEATURES;
    etext:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_VARIABLE_POINTER_FEATURES ->
    ename:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_VARIABLE_POINTERS_FEATURES;
    etext:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_VARIABLE_POINTER_FEATURES_KHR ->
    ename:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_VARIABLE_POINTERS_FEATURES_KHR;
    and etext:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_BUFFER_ADDRESS_FEATURES_EXT
    ename:VK_STRUCTURE_TYPE_PHYSICAL_DEVICE_BUFFER_DEVICE_ADDRESS_FEATURES_EXT.
    The old names are still available as aliases for backwards
    compatibility. This change required introducing valid XML markup which
    externally written XML processing scripts may need to be modified to
    accomodate, to support multiple aliases of a single command or token
    name (internal issue 1592).
  * Add slink:VkDevice as the first parameter to flink:vkSetLocalDimmingAMD
    (internal issue 1618).
  * Improve CI header compilation tests to test all Vulkan platform
    includes, using fake platform headers where needed, and change the
    `allchecks` Makefile target to use the more comprehensive
    `check_spec_links.py` script instead of the retired `checkinc` and
    `checklinks` targets.
  * Move descriptions of the ASTC compressed texture decode mode from the
    <<appendix-compressedtex-astc,appendix>> to the recently updated
    external Khronos Data Format Specification.
  * Fix minor markup and spelling issues in the `VK_NV_ray_tracing`
    extension.
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/b1042a3204aba3319e2a9b42afa969789472a458
Vulkan API specifications 1.1.107 released
« Reply #73 on: April 19, 2019, 07:36:20 PM »
Change log for April 16, 2019 Vulkan 1.1.107 spec update:
  * Update release number to 107.
Public Issues:
  * Fix revision date for the `<<VK_AMD_gpu_shader_half_float>>` appendix
    (public issue 617).
  * Make <<synchronization-pipeline-barriers-subpass-self-dependencies,
    subpass self-dependencies>> less restrictive (public issue 777).
  * Fix the `<<VK_EXT_full_screen_exclusive>>` dependency on
    `<<VK_KHR_win32_surface>>` in `vk.xml` (public pull request 849).
  * Remove single-page (`apispec.html`) refpage sub-targets from the
    Makefile `allman` target and the build instructions. The target is still
    present in the Makefile, but we have not been actively maintaining the
    single-page document and do not promise it will work. The full
    Specification and the individual API reference pages are what we support
    and publish at present (public issue 949).
Internal Issues:
  * De-duplicate common valid usage statements shared by multiple commands
    or structures by using asciidoctor includes and dynamically assigning
    part of the valid usage ID based on which command or structure they're
    being applied to (internal issue 779).
  * Add reference pages for constructs not part of the formal API, such as
    platform calling convention macros, and script changes supporting them
    This required suppressing some check_spec_links warning classes in order
    to pass CI, until a more sophisticated fix can be done (internal issue
    888).
  * Change math notation for the elink:VkPrimitiveTopology descriptions to
    use short forms `v` and `p` instead of `vertex` and `primitive`,
    increasing legibility (internal issue 1611).
  * Rewrite generated file includes relative to a globally specified path,
    fixing some issues with refpage generation (internal issue 1630).
  * Update contributor list for `<<VK_EXT_calibrated_timestamps>>`.
  * Fix use of pathlin in `scripts/generator.py` so the script will work on
    Windows under Python 3.5 (internal merge request 3107).
  * Add missing conditionals around the
    <<descriptorsets-accelerationstructure, Acceleration Structure>>
    section (internal merge request 3108).
  * More script synchronization with OpenXR spec repository (internal merge
    request 3109).
  * Mark the `<<VK_AMD_gpu_shader_half_float>>` and
    `<<VK_AMD_gpu_shader_int16>>` extensions as deprecated in `vk.xml` and
    the corresponding extension appendices (internal merge request 3112).
New Extensions:
  * `<<VK_EXT_headless_surface>>`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/5abf83f95d89cf6ba104b4c70d42d5c7c678b630
New extension:
- VK_EXT_headless_surface
Vulkan API specifications 1.1.108 released
« Reply #74 on: May 14, 2019, 04:19:02 PM »
Change log for May 13, 2019 Vulkan 1.1.108 spec update:
  * Update release number to 108.
Internal Issues:
  * Clarify that only external resources can be bound to external memory in
    valid usage statements for flink:vkBindBufferMemory,
    flink:vkBindImageMemory, slink:VkSparseMemoryBind, and
    slink:VkSparseImageMemoryBind (internal issue 1496).
  * Move all `vk.xml`requirements for
    flink:vkGetDeviceGroupSurfacePresentModes2EXT into
    `<<VK_EXT_full_screen_exclusive>>` (internal issue 1622).
  * Add some missing valid usage statements for
    flink:vkCmdEndQueryIndexedEXT (internal issue 1638).
  * Specify rules for defining "`New Flags and Bitmask Types`" in that
    section of the style guide (internal issue 1649).
  * Add a comment to the `vk.xml` extension block for
    `VK_ANDROID_native_buffer` explaining why the extension is tagged
    `"disabled"` (internal issue 1657).
  * Fix typos in the description of slink:VkImageViewCreateInfo (internal
    issue 1661).
  * Modify valid usage statements for slink:VkImageViewCreateInfo to fix the
    description about the restriction for pname:baseArrayLayer and
    pname:layerCount from pname:extent.depth to the depth of mipmap level
    while creating a 2D array image view on a 3D image.
  * Forbid structures that contain opaque types (images or samplers) in the
    SPIR-V <<spirvenv-module-validation, Validation Rules within a Module>>
    section.
  * Minor editorial changes for the `VK_EXT_swapchain_colorspace` extension
    in the description of slink:VkColorSpace KHR and `vk.xml`, including:
  ** Consistently specify which function (OETF or Inverse-EOTF) is being
     defined;
  ** Remove the Display P3 EOTF, since no other EOTFs are defined;
  ** Include luminance range for the HLG OETF;
  ** Remove a duplicated paragraph; and,
  ** Rename ename:VK_COLOR_SPACE_DISPLAY_P3_LINEAR_EXT, leaving the old
     ename:VK_COLOR_SPACE_DCI_P3_LINEAR_EXT token as an alias.
New Extensions:
  * `<<VK_NV_framebuffer_mixed_samples_coverage_reduction_mode>>`
  * `<<VK_KHR_uniform_buffer_standard_layout>>`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/40ba6e9a4468915aa3aef2ccc153d60e7988193f
New extensions:
- VK_KHR_uniform_buffer_standard_layout
- VK_NV_framebuffer_mixed_samples_coverage_reduction_mode: not yet documented.
Vulkan API specifications 1.1.109 released
« Reply #75 on: May 24, 2019, 05:07:39 PM »
Change log for May 24, 2019 Vulkan 1.1.109 spec update:
  * Update release number to 109.
Github Issues:
  * Require matching for physical devices to be in a device group in the
    <<devsandqueues-devices, Devices>> section (public issue 695).
  * Fix typo in an equation in the <<fragmentdensitymap-fetch-density-value,
    Fetch Density Value>> section (public issue 954).
  * Fix styleguide links (public pull request 965).
Internal Issues:
  * Allow <<renderpass-compatibility, compatibility of single-subpass
    renderpasses>> with different resolve attachments (internal issue 1464).
  * Add some missing empty flags types to API spec so custom refpage
    generation doesn't break (internal issue 1607).
  * Add a "`SPIR-V Sampled Type`" column to the <<formats-numericformat,
    Interpretation of Numeric Formats>> table, and clarify the requirement
    that the code:OpTypeImage sampled type match the bound image's numeric
    format for slink:VkClearColorValue and in the
    <<interfaces-resources-descset, Descriptor Set Interface>> section
    (internal issue 1646).
  * Fix a typo in the <<tessellation-quad-tessellation, Quad Tessellation>>
    section which should refer to rectangles, not triangles (internal issue
    1667).
  * Clarify the definition of time domains in elink:VkTimeDomainEXT
    (internal merge request 3110).
  * Add R10X6 and R12X4 formats to the <<formats-mandatory-features-10bit>>
    table (internal merge request 3137).
  * Don't require extern sync on wait/signal semaphores in `vk.xml` for
    flink:vkQueueSubmit and flink:vkQueueBindSparse (internal merge request
    3116).
  * Improve phrasing of compute and mesh shader size related to
    code:LocalSize and code:WorkgroupSize in
    slink:VkPhysicalDeviceMeshShaderPropertiesNV and
    slink:VkPhysicalDeviceMaintenance3Properties (internal merge request
    3156).
  * Make the flink:vkCmdBindShadingRateImageNV pname:imageView parameter
    optional in `vk.xml` (internal merge request 3157).
New Extensions:
  * `<<VK_INTEL_performance_query>>`
  * `<<VK_INTEL_shader_integer_functions2>>`
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/6635a81b5b9dea234faf967d54abf7241db371c9
New extensions:
- VK_INTEL_performance_query
- VK_INTEL_shader_integer_functions2
Vulkan API specifications 1.1.110 released
« Reply #76 on: June 04, 2019, 01:20:02 PM »
Change log for June 2, 2019 Vulkan 1.1.110 spec update:
  * Update release number to 110.
Github Issues:
  * Fix typo (public pull request 972).
  * Rename Pastel driver ID to SwiftShader (public pull request 974).
New Extensions:
  * `<<VK_EXT_fragment_shader_interlock>>`
  * `<<VK_NV_shader_sm_builtins>>`
Link: https://github.com/KhronosGroup/Vulkan-Docs/commit/619084d44a605285e39530a0810d323ad024f897
New extensions
- VK_EXT_fragment_shader_interlock
- VK_NV_shader_sm_builtins
Vulkan API specifications 1.1.111 released
« Reply #77 on: June 16, 2019, 05:30:23 AM »
Change log for June 10, 2019 Vulkan 1.1.111 spec update:
  * Update release number to 111.
Github Issues:
  * Clean up flink:vkGetPhysicalDeviceSurfaceFormatsKHR and
    flink:vkGetPhysicalDeviceSurfaceFormats2KHR to drop the
    ename:VK_FORMAT_UNDEFINED case, require callers pass a supported
    surface, and rearrange some validation-related language (public issue
    207).
  * Allow dynamic and nonuniform indexing of acceleration structures in the
    (public KhronosGroup/glslang issue 1766).
Internal Issues:
  * Clarify when images require the use of YCbCr samplers for
    slink:VkWriteDescriptorSet and slink:VkImageViewCreateInfo (internal
    issue 1639).
  * Remove the "`block`" language around <<features-robustBufferAccess,
    vectorizing and robust buffer access>> (internal issue 1642).
  * Allow code:OpTypeImageFormat == code:Unknown for input attachments in
    the <<interfaces-resources-descset, Descriptor Set Interface>> section
    (internal issue 1645).
  * Fix asciidoctor conditionals around
    ename:VK_ERROR_FULL_SCREEN_EXCLUSIVE_MODE_LOST_EXT in the
    <<fundamentals-errorcodes>> section (internal issue 1679).
  * Remove error codes from `vk.xml` for
    flink:vkUninitializePerformanceApiINTEL, which has a `void` return type
    (internal issue 1704).
  * Various subgroup-related fixes in the <<spirvenv-capabilities,
    Capabilities>>, <<shaders-subgroup-arithmetic, Arithmetic Subgroup
    Operations>>, <<shaders-subgroup-clustered, Clustered Subgroup
    Operations>>, and <<shaders-subgroup-partitioned, Partitioned Subgroup
    Operations>> sections (internal merge request 3164).
  * Fix asciidoctor markup affecting math rendering in the <<Precision of
    core SPIR-V Instructions>> table (internal merge request 3166).
  * Fix incorrect reference to flink:vkGetPhysicalDeviceFeatures2KHR in the
    description of slink:VkPhysicalDeviceASTCDecodeFeaturesEXT (internal
    merge request 3169).
  * Fix a non-sentence in the introduction to the <<textures, Image
    Operations Overview>> section (internal merge request 3184).
  * Minor markup, grammar, and typo fixes for the
    `<<NV_shader_sm_builtins>>` extension spec language (internal merge
    request 3189).
  * Clarify that 1D and 1D array format support is optional for cubic
    filters, immediately following the <<formats-mandatory-features-astc,
    Mandatory ASTC LDR format support>> table (internal merge request 3194).
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/ad46c7dc688fe973ac7299b651403be5f562db8e
Vulkan API specifications 1.1.117 released
« Reply #78 on: July 29, 2019, 04:36:42 PM »
Change log for July 28, 2019 Vulkan 1.1.117 spec update:
  * Update release number to 117.
Github Issues:
  * Add ename:VK_STENCIL_FACE_FRONT_AND_BACK for naming consistency, and
    alias the old ename:VK_STENCIL_FRONT_AND_BACK for backwards
    compatibility (public issue 991).
  * Fix minor issues with valid usage statements for
    flink:vkCreateFramebuffer, slink:VkFramebufferCreateInfo, and
    slink:VkRenderPassBeginInfo when the `<<VK_KHR_imageless_framebuffer>>`
    extension is enabled (public issue 998).
  * Clarify the subpass dependency requirement in the
    <<renderpass-layout-transitions>> section to eliminate the need for a
    subpass dependency for either the same or different layouts as long as
    they're both read-only (relates to
    KhronosGroup/Vulkan-ValidationLayers#948).
Internal Issues:
  * Document that <<extendingvulkan-compatibility-promotion, backwards
    compatibility aliases are not promoted>> as part of promoting an
    extension (internal issue 1677).
  * Update VK_ANDROID_native_buffer extension to spec version 8 (internal
    issue 1753).
  * Add missing section to the <<VK_KHR_shader_controls_v4_incompatibility,
    VK_KHR_shader_float_controls>> extension appendix describing
    the reason for the breaking API change in version 4 of the extension,
    and correct the version to 4 in `vk.xml` (internal merge request
    3275).
  * Add valid usage statements to slink:VkAccelerationStructureInfoNV
    requiring the ename:VK_BUFFER_USAGE_RAY_TRACING_BIT_NV usage flag for
    buffers used in acceleration structure building.
New Extensions:
  * `<<VK_EXT_line_rasterization>>`
  * `<<VK_EXT_texture_compression_astc_hdr>>`
  * `<<VK_EXT_index_type_uint8>>`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/0e3ceb7574dacde2a10f15718ba0cbc92c9905c8
New extensions:
- VK_EXT_line_rasterization
- VK_EXT_texture_compression_astc_hdr
- VK_EXT_index_type_uint8
Vulkan API specifications 1.1.118 released
« Reply #79 on: August 13, 2019, 09:44:11 AM »
Change log for August 11, 2019 Vulkan 1.1.118 spec update:
  * Update release number to 118.
Github Issues:
  * Update `BUILD.adoc` to specifically require asciidoctor 1.5.8, and make
    that change to the gitlab CI script (public issue 968).
  * Remove redundant slink:VkSubpassDependency and
    slink:VkSubpassDependency2KHR valid usage statements
    (public pull request 995).
  * Clarify the <<vkGetInstanceProcAddr behavior>> and <<vkGetDeviceProcAddr
    behavior>> tables (public pull request 1004).
  * Fix use of nonexistent
    slink:VkSamplerYcbcrConversionImageFormatProperties::pname:maxCombinedImageSamplerDescriptorCount
    (public pull request 1010).
  * Use compatible pathlib for python2 (public pull request 1012).
Internal Issues:
  * Mark the <<VK_KHR_vulkan_memory_model>> extension as no longer
    provisional in `vk.xml` (internal issue 1369).
  * Clarify that use-defined code:Input and code:Output variables cannot be
    code:Boolean in the <<interfaces-iointerfaces-user, User-defined
    Variable Interface>> section (internal issue 1663).
  * Fix naming inconsistencies in
    slink:VkPhysicalDevicePerformanceQueryFeaturesKHR,
    slink:VkPhysicalDevicePerformanceQueryPropertiesKHR,
    slink:VkQueryPoolPerformanceCreateInfoKHR, and associated enumerants
    (internal issue 1746).
  * Use ACM reference style for normative references (internal merge request
    3256).
  * Explicitly list the features changed in Vulkan 1.1 in the
    <<features-requirements, Feature Requirements>> section and the
    <<versions, Core Revisions (Informative)>> appendix (internal merge
    request 3274).
  * Add the slink:VkPhysicalDeviceSubgroupSizeControlFeaturesEXT structure
    to the <<VK_EXT_subgroup_size_control>> extension, which was
    accidentally omitted in the initial release of the extension (internal
    merge request 3287).
  * Add missing slink:VkImageUsageFlag description for
    ename:VK_IMAGE_USAGE_FRAGMENT_DENSITY_MAP_BIT_EXT (internal merge
    request 3292).
  * Add valid usage statements to slink:VkAccelerationStructureInfoNV and
    flink:vkGetAccelerationStructureHandleNV to clarify usage of
    acceleration structure handle and geometries (internal merge request
    3292).
New Extensions:
  * `<<VK_AMD_shader_core_properties2>>`
  * `<<VK_AMD_pipeline_compiler_control>>`
source: https://github.com/KhronosGroup/Vulkan-Docs/commit/94f03f1ccaecf6403d44fbe3de78d033e396bc58
New extensions:
- VK_AMD_shader_core_properties2
- VK_AMD_pipeline_compiler_control
