NVIDIA ForceWare 190.62 WHQL Drivers available
Started by Stefan, August 22, 2009, 09:09:18 AM
Get it from NVIDIA.
QuoteNew in Release 190.62
    * Adds WHQL support on Windows 7 for Microsoft's new DirectX GPU Computing API: DirectCompute.
    * Optimized for the latest PhysX gaming titles: Batman: Arkham Asylum and Darkest of Days.
    * Installs PhysX System Software version 9.09.0814.
Fixed Issues–Windows XP 32-bit
Single-GPU Resolved Issues and Changes
•GeForce 9 Series (2x): With a TV connected to S-Video, the display turns
blank after opening the NVIDIA Control Panel, requiring the user to reboot
the system. [445384]
•GeForce 9800 GTX: Far Cry 2–with the in-game resolution set to 1920x1200
and antialiasing set to 2x or higher, there is corruption when looking up at
the sky. [555163]
Multi-GPU Resolved Issues and Changes
•[SLI], GeForce 200 Series: After changing the multi-GPU display settings and
then rebooting the system, the display remains at the original multi-GPU
setting. [504028]
•[SLI], GeForce 7 Series: There is no confirmation popup when some changes
are made in the NVIDIA Control Panel. [511417]
Fixed Issues–Windows XP 64-bit
•GeForce 9800 GX2: Rainbow Six Vegas 2–the game hangs or crashes before
the loading screen when launched with the default settings. [570878]
•[SLI], GeForce 8600 GT: The display resolution changes after enabling or
disabling SLI mode. [541902]
Windows Vista 64-bit Issues
•[SLI], GeForce 7 Series: There is no confirmation popup when some changes are
Fixed Issues–Windows 7 (32-bit)
Single GPU Resolved Issues
•GeForce 9500 GS: With a VGA and S-Video display connected in Clone mode, the
NVIDIA Control Panel Change REsolution controls do not work. [558589]
Fixed Issues Windows 7 (64-bit)
•[Quad-SLI], GeForce 7950 GX2: Quad SLI cannot be enabled when the NVIDIA
Control Panel is maximized. [575191]
