Author Topic: GeeXLab not opening properly under Windows 10  (Read 10086 times)
allydonaldson
« on: February 03, 2016, 10:59:45 AM »
Hey - I'm trying GeeXLab for the first time.  I downloaded the .zip file (Windows, 64-bit, version 0.9.4.1), and opened GeeXLab.exe.  I find that the program appears on my task bar (I get a GL icon), and when I hover over this icon I see a thumbnail of what looks like a launched application, with "File", "Tools" and "Help" menus.  However, when I click on this icon nothing comes up.
Has anyone come across this problem and have ideas about a solution?
Thanks!
Ally
Re: GeeXLab not opening properly under Windows 10
« Reply #1 on: February 03, 2016, 11:34:09 AM »
Could you post the content of the log file (_geexlab_log.txt) ? You should find this file in GeeXLab folder.
allydonaldson
« Reply #2 on: February 03, 2016, 01:50:44 PM »
Sure - please see below.  Looking forward to hearing whether this raises any ideas.
Thanks
Ally
2016/2/3@11:37:00(0000000001) < > GeeXLab v0.9.4.1 (Jan 20 2016@18:23:27)
2016/2/3@11:37:00(0000000002) < > Cross Platform Lab for Real Time 3D Programming and Demo Coding
2016/2/3@11:37:00(0000000003) < > (C)2009-2016 Geeks3D (www.geeks3d.com)
2016/2/3@11:37:00(0000000004) < > GeeXLab is starting up...
2016/2/3@11:37:00(0000000005) < > [CHECKVERSION] Checking for new version...
2016/2/3@11:37:00(0000000006) < > Windows version: Windows 10 build 10586
2016/2/3@11:37:00(0000000007) < > platform: Windows 64-bit
2016/2/3@11:37:00(0000000008) < > Command line:
2016/2/3@11:37:00(0000000009) < > Plugin search path: C:\Users\afd\GeeXLab_FREE_win64\/plugins/
2016/2/3@11:37:00(0000000010) < > [OpenCL] OpenCL computing plugin (OpenCL 1.1, 1.2)
2016/2/3@11:37:00(0000000011) <!> Python 2.7 installation not found: unable to load Python core library (python27.dll).
2016/2/3@11:37:00(0000000012) <!> Unable to load plugin plugin_gxl_python_27_x64.dll
2016/2/3@11:37:01(0000000013) < > [FBX] Autodesk FBX 3D object loader plugin. Supported formats: *.fbx, *.3ds, *.obj
2016/2/3@11:37:01(0000000014) < > [PhysX3] NVIDIA PhysX plugin based on PhysX SDK v3.x.x
2016/2/3@11:37:01(0000000015) < > [FFmpeg] FFmpeg plugin (audio / video)
2016/2/3@11:37:01(0000000016) < > [GpuMonitor] GPU monitoring plugin for NVIDIA and AMD GPUs
2016/2/3@11:37:01(0000000017) < > [GpuMonitor] Operating system detected: Windows 10 build 10586
2016/2/3@11:37:01(0000000018) < > [CHECKVERSION] Unable to connect to www.ozone3d.net - Check for new version failed.
2016/2/3@11:37:01(0000000019) < > [GpuMonitor] Num GPUs found: 1
2016/2/3@11:37:01(0000000020) < > [GpuMonitor] GPU0 - Intel(R) HD Graphics 520
2016/2/3@11:37:01(0000000021) < > [GpuMonitor] GPU0 - PCI codes: 0x8086-0x1916
2016/2/3@11:37:01(0000000022) < > [GpuMonitor] GPU0 - BIOS: Intel Video BIOS
2016/2/3@11:37:01(0000000023) < > [GpuMonitor] GPU0 - driver: Intel 20.19.15.4326 (11-18-2015) GL:ig9icd64.dll
2016/2/3@11:37:02(0000000024) < > [FMOD] FMOD audio engine plugin
2016/2/3@11:37:03(0000000025) < > [FreeImage] FreeImage image loader. Supported formats: *.JPEG, *.PNG, *.TGA, *.BMP, *.PSD, *.GIF, *.HDR, *.PIC
2016/2/3@11:37:03(0000000026) < > [FreeImage] version: 3.17.0
2016/2/3@11:37:03(0000000027) < > [AntTweakBar] AntTweakBar plugin
2016/2/3@11:37:03(0000000028) < > [LeapMotion] Leap Motion plugin
2016/2/3@11:37:03(0000000029) < > [LeapMotion] - no Leap device detected
2016/2/3@11:37:04(0000000030) < > [FreeTypeGL] FreeTypeGL plugin
2016/2/3@11:37:04(0000000031) < > [heman] heman: tiny MIT-licensed C99 library of image utilities for dealing with height maps, normal maps, distance fields - https://github.com/prideout/heman
2016/2/3@11:37:04(0000000032) < > [OpenCL] initializing OpenCL data...
2016/2/3@11:37:05(0000000033) < > [OpenCL] found 1 OpenCL platform(s)
2016/2/3@11:37:05(0000000034) < > [OpenCL] Platform 0
2016/2/3@11:37:05(0000000035) < > [OpenCL] - vendor: Intel(R) Corporation
2016/2/3@11:37:05(0000000036) < > [OpenCL] - name: Intel(R) OpenCL
2016/2/3@11:37:05(0000000037) < > [OpenCL] - profile: FULL_PROFILE
2016/2/3@11:37:05(0000000038) < > [OpenCL] - version: OpenCL 2.0
2016/2/3@11:37:05(0000000039) < > [OpenCL] Platform 0 - devices count: 2
2016/2/3@11:37:05(0000000040) < > [OpenCL] - Device 0 - name: Intel(R) HD Graphics 520 - Compute units: 24 @ 1050MHz
2016/2/3@11:37:05(0000000041) < > [OpenCL] - Device 1 - name: Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz - Compute units: 4 @ 2500MHz
2016/2/3@11:37:05(0000000042) < > [OpenCL] OpenCL data initialized ok.
2016/2/3@11:37:05(0000000043) <*> [PhysX3] unable to read PhysX version. Try to re-install the PhysX runtimes.
2016/2/3@11:37:05(0000000044) < > [FFmpeg] plugin started OK (id=10).
2016/2/3@11:37:05(0000000045) <!> Unable to start the PhysX 3 plugin. Unloading it...
2016/2/3@11:37:05(0000000046) < >  PhysX 3 plugin unloaded.
2016/2/3@11:37:05(0000000047) < > App directory: C:\Users\afd\GeeXLab_FREE_win64\
2016/2/3@11:37:05(0000000048) < > Scripting libs directory: C:\Users\afd\GeeXLab_FREE_win64\libs/
2016/2/3@11:37:05(0000000049) < > Command line:
2016/2/3@11:37:05(0000000050) < > [Lua core plugin] Lua version: Lua 5.3.1
2016/2/3@11:37:05(0000000051) < > [Lua] lfs library loaded ok
2016/2/3@11:37:05(0000000052) < > [Lua] LuaSockect library loaded ok
2016/2/3@11:37:05(0000000053) < > [Lua] mime (LuaSockect) library loaded ok
2016/2/3@11:37:05(0000000054) < > [Lua] LuaGL library loaded ok
2016/2/3@11:37:05(0000000055) < > [Lua] lfs library loaded ok
2016/2/3@11:37:05(0000000056) < > [Lua] LuaSockect library loaded ok
2016/2/3@11:37:05(0000000057) < > [Lua] mime (LuaSockect) library loaded ok
2016/2/3@11:37:05(0000000058) < > [Lua] LuaGL library loaded ok
2016/2/3@11:37:05(0000000059) < > [Lua] API libraries initialized ok.
2016/2/3@11:37:05(0000000060) < > GXLAPP_Demo::init_window3d() - msaa: Off
2016/2/3@11:37:05(0000000061) < > scene::default - demo started with an OpenGL 4.4 context.
2016/2/3@11:37:05(0000000062) < > Quick OpenGL information [scene::default]:
2016/2/3@11:37:05(0000000063) < > GL_RENDERER: Intel(R) HD Graphics 520
2016/2/3@11:37:05(0000000064) < > GL_VENDOR: Intel
2016/2/3@11:37:05(0000000065) < > GL_VERSION: 4.4.0 - Build 20.19.15.4326
2016/2/3@11:37:05(0000000066) < > GL_SHADING_LANGUAGE_VERSION: 4.40 - Build 20.19.15.4326
2016/2/3@11:37:05(0000000067) < > OpenGL version detected: 4.4
2016/2/3@11:37:05(0000000068) < > OpenGL extensions: 223
2016/2/3@11:37:05(0000000069) < > OpenGL hardware capabilities:
2016/2/3@11:37:05(0000000070) < >   GL_MAX_VERTEX_ATTRIBS: 16
2016/2/3@11:37:05(0000000071) < >   GL_MAX_VERTEX_UNIFORM_COMPONENTS: 4096
2016/2/3@11:37:05(0000000072) < >   GL_MAX_FRAGMENT_UNIFORM_COMPONENTS: 4096
2016/2/3@11:37:05(0000000073) < >   GL_MAX_VARYING_FLOATS: 64
2016/2/3@11:37:05(0000000074) < >   GL_MAX_TEXTURE_SIZE: 16384
2016/2/3@11:37:05(0000000075) < >   GL_MAX_VIEWPORT_DIMS: 16384 16384
2016/2/3@11:37:05(0000000076) < >   GL_MAX_TEXTURE_IMAGE_UNITS: 32
2016/2/3@11:37:05(0000000077) < >   GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS: 192
2016/2/3@11:37:05(0000000078) < > Render window initialized (scene::default)
2016/2/3@11:37:05(0000000079) < > [Lua] lfs library loaded ok
2016/2/3@11:37:05(0000000080) < > [Lua] LuaSockect library loaded ok
2016/2/3@11:37:05(0000000081) < > [Lua] mime (LuaSockect) library loaded ok
2016/2/3@11:37:05(0000000082) < > [Lua] LuaGL library loaded ok
2016/2/3@11:37:55(0000000083) < > # frames rendered: 12400
2016/2/3@11:37:55(0000000084) < > [OpenGL] [OpenGL] GPU program (color_prog / 24 / 1) unloaded from GPU memory
2016/2/3@11:37:55(0000000085) < > [FFmpeg] plugin stopped OK (id=10).
2016/2/3@11:37:55(0000000086) < > Stopping GeeXLab...
2016/2/3@11:37:55(0000000087) < > Exit from GeeXLab.
« Reply #3 on: February 03, 2016, 02:07:20 PM »
There's no visible problem in the log file. Everything looks ok.
I have a test system with an Intel HD Graphics 530, let me do a quick test...
« Reply #4 on: February 03, 2016, 02:52:16 PM »
GeeXLab 0.9.4.1 works fine on my Win10 64-bit + HD Graphics 530 GPU (with Intel drivers v4352). Your driver is v4326. I don't think that will make a difference but you can install latest Intel graphics drivers. Maybe you have an antivirus or firewall that is blocking GeeXLab. You can also try the 32-bit version of GeeXLab... Let me know.
allydonaldson
« Reply #5 on: February 04, 2016, 10:59:54 AM »
I updated my drivers, and also tried the 32-bit version - didn't solve the issue.
Never mind: I will try from a different laptop, which hopefully will work; I'll post again if it doesn't.
Thanks for your suggestions.
allydonaldson
« Reply #6 on: February 04, 2016, 04:36:39 PM »
Works fine on another laptop (with an Iris GPU), so must be some odd issue with the previous laptop I tried.
« Reply #7 on: February 04, 2016, 08:24:22 PM »
Great!
I though about two other things you can try on your previous laptop:
1/ try to rename the plugins/ folder so GeeXLab can't load plugins. There is perhaps an issue with a plugin.
2/ disable the online check for newer versions. You can disable this check with an additional option in command line:
GeeXLab.exe /no_online_check
allydonaldson
« Reply #8 on: February 04, 2016, 08:47:17 PM »
Thanks for the ideas.
I tried #1 first - I renamed "plugins" to "pluginstemp".  When I opened GeeXLab I then got a popup about a newer version being available (looks like one was released today).  So, it seems like the checking for updates is working.
I got this new version.  I found I had the same problem as my initial issue.  I then tried renaming "plugins" to "pluginstemp"; this did not help.  I then tried your suggestion #2; unfortunately this did not help either (perhaps not surprising, since it did appear that the older version was able to successfully check for updates).
I'm happy to try other ideas if you have them.  But from my project's perspective, I can work with the version that is running on my other laptop.
Cheers
Ally
