It seems to me there was a problem to use keyboard javascript code (i guess the translation wasnt done in the way i needed).
So i did another translation which works for me. It's done with the string library from lua. It should be easier than the use than several variable "KC_SPACE and KC_ESCAPE" because now one just need to do an iteration "for loop" on the "key" table to call whatever you want. Even if anyone want to reverse the table (make the index being the value and the value the index) it's possible from an for loop. The complete key table is below.
hope it can be useful for someone
There are only a few key missing : the right CTRL key, and the right shift. Not a big deal, but if someone knows why it's missing, i'd be glad.
To use it : very easy : put it in a file .lua, like "key.lua" then put it in the libs/lua folder.
Then use "dofile".
Then I'm using the following code :
local lib_dir = gh_utils.get_scripting_libs_dir()
dofile(lib_dir .. "lua/key.lua")
local kbcode,state
gh_window.keyboard_update_buffer(0)
--KEYBOARD STATUS
for k,v in pairs(key) do
kbcode=k
for k1,v1 in pairs(key[k]) do
if k1>1 then
state=gh_input.keyboard_is_key_down(key[k][k1])
end
end
if state==1 then text(kbcode,state,key[kbcode][1]) end
end
function text(keycode,status,str)
gh_imgui.text(string.format("%d_%d_%s",keycode,status,str))
end
Here the keyboard table mapping
key={}
key[8]={"backspace", 14 }
key[9]={"tab", 15 }
key[13]={"enter", 156,28 }
key[16]={"shift", 54,42 }
key[17]={"ctrl", 157,29 }
key[18]={"alt", 184,56 }
key[19]={"pause", 223 }
key[20]={"capital", 58 }
key[27]={"escape", 1 }
key[32]={"space", 57 }
key[33]={"pageup", 201 }
key[34]={"pagedown", 209 }
key[35]={"_end", 207 }
key[36]={"home", 199 }
key[37]={"left", 75 ,203}
key[38]={"up", 72,200 }
key[39]={"right", 77 ,205}
key[40]={"down", 80 ,208}
key[45]={"insert", 210 }
key[46]={"delete", 211 }
key[48]={"_0", 11 }
key[49]={"_1", 2 }
key[50]={"_2", 3 }
key[51]={"_3", 4 }
key[52]={"_4", 5 }
key[53]={"_5", 6 }
key[54]={"_6", 7 }
key[55]={"_7", 8 }
key[56]={"_8", 9 }
key[57]={"_9", 10 }
key[65]={"a", 30 }
key[66]={"b", 48 }
key[67]={"c", 46 }
key[68]={"d", 32 }
key[69]={"e", 18 }
key[70]={"f", 33 }
key[71]={"g", 34 }
key[72]={"h", 35 }
key[73]={"i", 23 }
key[74]={"j", 36 }
key[75]={"k", 37 }
key[76]={"l", 38 }
key[77]={"m", 50 }
key[78]={"n", 49 }
key[79]={"o", 24 }
key[80]={"p", 25 }
key[81]={"q", 16 }
key[82]={"r", 19 }
key[83]={"s", 31 }
key[84]={"t", 20 }
key[85]={"u", 22 }
key[86]={"v", 47 }
key[87]={"w", 17 }
key[88]={"x", 45 }
key[89]={"y", 21 }
key[90]={"z", 44 }
key[91]={"lwin", 219 }
key[92]={"rwin", 220 }
key[96]={"numpad0", 82 }
key[97]={"numpad1", 79 }
key[98]={"numpad2", 80 }
key[99]={"numpad3", 81 }
key[100]={"numpad4", 75 }
key[101]={"numpad5", 76 }
key[102]={"numpad6", 77 }
key[103]={"numpad7", 71 }
key[104]={"numpad8", 72 }
key[105]={"numpad9", 73 }
key[106]={"multiply", 55 }
key[107]={"add", 78 }
key[109]={"subtract", 74 }
key[110]={"decimal", 83 }
key[111]={"divide", 181 }
key[112]={"f1", 59 }
key[113]={"f2", 60 }
key[114]={"f3", 61 }
key[115]={"f4", 62 }
key[116]={"f5", 63 }
key[117]={"f6", 64 }
key[118]={"f7", 65 }
key[119]={"f8", 66 }
key[120]={"f9", 67 }
key[121]={"f10", 68 }
key[122]={"f11", 87 }
key[123]={"f12", 88 }
key[144]={"numlock", 69 }
key[145]={"scroll", 70 }
